*Which oil to use on Built Turbo'd motor?? Opinions please
Old Dec 6, 2008 | 11:59 PM
ITRBOY1433's Avatar
Default *Which oil to use on Built Turbo'd motor?? Opinions please
Like title states, im wondering which is the best oil to use on a built GSR sleeved turbo'd motor? as of now its on Castrol non synthetic 20w50 , motor has approx 4,600miles, and that's been the oil used since it was built. I just think it may be too thick for that motor. Any opinions on which to switch to? or leave it as IS?
Old Dec 7, 2008 | 05:19 AM
cashkeith's Avatar
5w30
Old Dec 7, 2008 | 05:25 AM
delsol8017's Avatar
royal purple 5w30
Old Dec 7, 2008 | 06:45 AM
91blackEF's Avatar
i second the royal purple for any built motor ^^
Old Dec 7, 2008 | 08:03 AM
Blzdeep's Avatar
Originally Posted by delsol8017
royal purple 5w30
x2
Old Dec 7, 2008 | 08:19 AM
burningrex's Avatar
so you got the motor freshly built and you haven't changed the oil since it was built?
Old Dec 7, 2008 | 08:46 AM
ITRBOY1433's Avatar
^yea sure iam an idiot. No bro, i bought the car and the guy who had it before me who had a shop do the work has been using 20w50... now if i switch to royal purple 5w30 will it have any side effects since its been running on such a thick oil? and at how many miles do you do the next oil change on royal purple?
Old Dec 7, 2008 | 11:54 AM
ITRBOY1433's Avatar
Old Dec 7, 2008 | 04:46 PM
91blackEF's Avatar
i do the same as a normal oil change just check it like you would do any oil but if you go and change it this time and theres any debris or metal shaving in it from the fresh re build then you eathier might not wanna use the royal purple just yet cause you dont wanna have to change it agian 500 miles down the road
Old Dec 7, 2008 | 09:23 PM
ITRBOY1433's Avatar
any others?
Old Dec 8, 2008 | 03:49 AM
black_EM1's Avatar
Community Builder
Community Influencer
I ran Mobil1 0w30 on my turbo setups.
Old Dec 8, 2008 | 04:51 AM
crick_james's Avatar
castrol gtx 5w30
Old Dec 8, 2008 | 07:35 AM
Marauder's Avatar
I always ran Mobil 1 5w30 in mine. changed every 3000 miles, and have had no problems with 50k miles on the motor after the turbo went on.
Old Dec 8, 2008 | 07:53 AM
boostin350z's Avatar
eneos 10w40 best oil out there
Old Dec 8, 2008 | 08:23 AM
H22honda!@!'s Avatar
MOTUL 5w30
Old Dec 8, 2008 | 08:31 AM
96 GSR-T's Avatar
I used the RP 10w40 over the summer and I was not very fond of it, it leaks out places that other oils dont (why I dont know), switched to Castrol GTX and 10w40 in the summer and the car felt MUCH smoother, and stopped leaking. I change my oil every 1k miles so I dont feel the need to run an expensive oil, my oil is still pretty much clear when I change it.
Old Dec 8, 2008 | 08:38 AM
tony1's Avatar
This is the best oil i've found. The ONLY oil i've seen stop the cam and rocker wear problems common in high rpm/high spring pressure race applications. We went from changing cams and rockers every 3-4 events using Mobil 1 15/50 synthetic to having over a year of racing on things with Brad Penn 20w50. It's all we use here now. After seeing the results first hand, i'll never use anything else. Not to mention it's very reasonably priced.
http://www.t1raceparts.com/product_p...cing%20oil.htm
Old Dec 8, 2008 | 08:46 AM
ITRBOY1433's Avatar
so it shouldnt matter if im going from 20w50 to 10w40 or something like that?
Old Dec 8, 2008 | 09:59 AM
Turbo-LS's Avatar
technically no. i personally run 4 qts 10w40 and 1 20w50 in new england its cold in the winter. i plan on straight 20w50 this summer though i run valvoline or castrol without any issues just reg motor oil.
really depends on how much you hammer the car and idle the car to how much viscosity break down your going to get and how much fuel will get into the oil. i generally change my oil every 2000 miles unless i hammer the car and getting to thin from fuel then 1500 miles but everyone has there own opinions. its really what you feel is ok
Old Dec 8, 2008 | 10:04 AM
extralargenog's Avatar
I experienced the exact same problem with Mobile 1.
Ive had these exact same EXCELLENT results witgh the Royal Purple 10-40. Ive heard the same of the Brad Penn..
The ZInc dithiophospahte and synthetic packages are very very effective, and yo WONT find the levels of it in a run of the mill US produced pil due to EPA restrictions.
Old Dec 8, 2008 | 10:13 AM
twkdCD595's Avatar
I run Brad Penn I get through T1, very reasonable price, has higher levels of zddp, etc. definately a good oil for sure.
Old Dec 8, 2008 | 10:38 AM
CRX T-Si's Avatar
Don't understand why your running such a thick oil but only the original engine builder will know that for sure. If you can find out what your bearing clearances were to give you idea what kind of oil you should use.
I was using Mobil 1 10w-30 forever but I just decided to switch to Castrol Syn 10w-30.
Old Dec 8, 2008 | 07:10 PM
ITRBOY1433's Avatar
a local shop owner suggested mobil1 15-50 any takers?
Old Dec 8, 2008 | 08:32 PM
Turbo B18C EJ6's Avatar
Im running Torco 5w40 synthetic on my turbo gsr
Old Dec 8, 2008 | 08:35 PM
tegman23's Avatar
valvoline racing oil 5w30 works great for me 400whp
