window problem
Old Dec 6, 2008 | 08:12 AM
GuitarPunk015's Avatar
Default window problem
last night a rolled my driver window down in my 97 civic and it won;t go back up! when you push the switch it will start to roll it up but stop after bout an inch and same goin back up, it's stuck half down and freezing outside....any ideas??
Old Dec 6, 2008 | 08:19 AM
VTECROAR96typeR's Avatar
did you try taking the door panel off to see if theres anything wrong inside you might just have to grease it up..
Old Dec 6, 2008 | 08:21 AM
i took it apart a little bit ago, just seems like its seized up, the right side of the window is like on the outside of the rubber instaed of the inside but i can't get the window to move to fix it
Old Dec 6, 2008 | 10:19 AM
anybody??
Old Dec 6, 2008 | 10:36 AM
Mrmatt3465's Avatar
So its caught in the window channel? Will it move if you take the window channel out? Take the channel out then put it back in x]. Thats what I would do.
Old Dec 7, 2008 | 10:06 AM
i took it apart and it was just out of the channel track, got it back together and it works great! thanks
Old Dec 7, 2008 | 11:22 AM
tercel95's Avatar
This has probably happened to 1 in every 3 EK owners, its a known problem with these cars.
The Destroyer
Sep 21, 2009 10:49 AM
ModdedByA1auto
Mar 10, 2009 08:56 AM
deerman2701
Nov 27, 2007 05:59 AM
mika
Jan 9, 2005 04:42 PM
type Gendy
May 18, 2004 07:37 PM
