WTF is wrong w/ my tranny
Old Dec 5, 2008 | 07:42 PM
dillonG_B's Avatar
Default WTF is wrong w/ my tranny
so i was just takin off to cross the intersection and my tranny just stoped working. The axles wiggle when its in gear but wont go, there is also a grinding noise. i dont think its the clutch, but idk. Any ideas and or what could be done to fix?
Old Dec 5, 2008 | 11:01 PM
SoCal EJ1's Avatar
t/o bearing? pressure plate?
Old Dec 5, 2008 | 11:33 PM
dmdzlpwr's Avatar
I had just about the same f-ing problem yesterday! I have a '00 LX with a B16 and a gsr tranny. I was doing about 45 in 5th and got the slipping like it popped out of gear and the grinding. I pulled over, moved the shifter around a little, clutch worked fine, took off in 1st, going fine, went to 2nd, went fine for about 20ft. then started slipping again, tried 3rd and 4th, same ****. It would move a little and make the grinding noise like the gears just aren't 100% engaged. Maybe a bent fork? Got pissed off, tried 1st again, and drove home 40mph@8400rpm. I bought the car 3 months ago, it had an SI tranny in it. 3 days after I had it, I was in 4th, something popped and snapped inside tranny. Cogs that make up 4th gear shattered due to lack of oil. I pulled the drainplug before pulling the axles out and about a half cup of oil came out. The douche-bag told me, "I take very good care of my cars". It showed. I'll pull this gsr tranny next weekend and tear it apart to see what the problem is.
Old Dec 5, 2008 | 11:35 PM
bigwally9876's Avatar
its your throw out bearing... Time to upgrade :D
Old Dec 6, 2008 | 04:54 AM
cherroneballs's Avatar
check the axle, it could have popped out, I seen it happen, once before it's rare but possible.
DA9teg93
Jun 12, 2005 04:09 AM
Unjockable
Oct 24, 2003 08:41 AM
It's Blue
Oct 13, 2002 06:51 PM
It's Blue
Oct 13, 2002 09:27 AM
