B16 Intake Manifold - What connects to this nipple? (pic)
Old Dec 5, 2008 | 04:32 PM
KeithDigital's Avatar
Default B16 Intake Manifold - What connects to this nipple? (pic)
I think this may be a B16 Del Sol intake manifold? It says P30 on the back. Anyway, there are two coolant nipples in the picture. I know where the big one goes, but what about the little one? I have never seen an intake manifold with that little one.
Thanks.
Old Dec 5, 2008 | 04:37 PM
saywhat's Avatar
Does it loop through the throttle body?
Old Dec 5, 2008 | 04:42 PM
Rok_Stok's Avatar
It's definitely a coolant outlet. It looks like hose #3 "Bypass Outlet Hose" attaches to it.
Old Dec 5, 2008 | 06:53 PM
#3 goes to the big nipple. Check out my post below with the red lines.
Old Dec 5, 2008 | 06:57 PM
jeremyrocksursox's Avatar
don't you mean #6? that looks more acurate
Old Dec 5, 2008 | 07:05 PM
sk8shorty012's Avatar
goes to #5 in the diagram.
Old Dec 5, 2008 | 08:58 PM
Rok_Stok's Avatar
Oh okay, now I know how to read those lines... they correspond to the other line with the same angle.
The bottom of hose #5 connects to the nipple. The top of hose #3 connects to the big nipple. Shweet. Never understood those lines before, never had too I guess.
Old Dec 6, 2008 | 05:46 AM
Yea it took me a while to read the diagrams but I finally got it to
The first diagram that Rok Stok posted shows that the little nipple on the intake manifold goes to the front of the TB for the FITV, correct?
My question now is, that can't be correct I thought the front of the TB for the FITV connects to this water outlet:
Just like in the diagram of the 2000 Civic Si:
Old Dec 6, 2008 | 07:11 AM
If you try to put the P30 manifold on you're si you're going to find yourself short a line, because you don't have anything to run to the smaller nipple. What I did was get the piece #6 in that middle diagram WITHOUT the nipple and then ran that extra line to the manifold nipple.
Make sense?
Old Dec 7, 2008 | 05:06 PM
I think I might have figured it out. I think I need the Del Sol water outlet with the Del Sol Intake Manifold. On the Del Sol, the water source for the FITV is out of the IM, on the Si it comes out of the Water Outlet. If I have the Del Sol IM and the Si Water Outlet I would have two sources for one FITV!! Too many. (This is exactly what Sk8shorty said).
Sk8shorty - #6 (Water Outlet) without the nipple is the Del Sol or ITR piece correct?
e0325
Apr 30, 2015 03:34 AM
gnccracer18
Mar 24, 2008 06:14 PM
Frost_1097
Jul 6, 2007 09:38 PM
PINKS
Apr 20, 2006 01:18 PM
Gunns
Aug 15, 2003 09:35 AM
