Pulling Out the Radio
Old Aug 2, 2002 | 08:27 AM
Flux's Avatar
Default Pulling Out the Radio
How difficult is it? Anybody have a quick step by step procedure?
I've gotta get the serial number off there so I can get my radio code...
Old Aug 2, 2002 | 08:32 AM
yoshi234's Avatar
I shoot brides
Default Re: Pulling Out the Radio (Flux)
there are two bolts that hold the radio in from behind. You can unbolt or even unscrew it (philips #2).
If you can't reach it, remove the ash tray assy. Reach thru there and remove the bolts.
The radio should slide right out.
warning: lots of sharp edges back there....dont cut yourself like i did and bleed all over the carpet
Old Aug 2, 2002 | 08:49 AM
red97gsr's Avatar
This is the guide I followed to remove mine
http://integra.cyberglobe.net/caraudio/diagrams/removal/
Old Aug 2, 2002 | 10:46 AM
Understeer's Avatar
Default Re: Pulling Out the Radio (red97gsr)
Take the out armrest, console etc. I tried taking it out by crawling under the passenger side, and its got little room to work with, Wear some gloves, cause my hand was all bleeding by the time I got it out.
Old Aug 2, 2002 | 10:48 AM
dohcsideSi's Avatar
Default Re: Pulling Out the Radio (yoshi234)
damn straight be careful back there!!
Old Aug 2, 2002 | 10:59 AM
hungsteR's Avatar
Flux, do you have a Helms manual? If you are going to be doing stuff on your own It's a great resource to start off with. It helps me a lot.
Old Aug 2, 2002 | 11:00 AM
Flux's Avatar
Default Re: Pulling Out the Radio (hungsteR)
Yah, I have a manual and I use it all the time.. I'm at work on a Friday and the Helms was at home and I was curious about he procedure and thought I'd ask...
Old Aug 2, 2002 | 11:06 AM
SoCal ITR's Avatar
Easiest way...
Remove armrest plastic, remove plastic piece around hand brake, then remove ashtray area
After I did that, I layed with my back on the passenger side floor with my legs out of the car and reached up underneath. I only had one screw in holding in the CD player....
Old Aug 2, 2002 | 11:51 AM
hungsteR's Avatar
LOL, juss makin' sure
wilaivue
Jun 2, 2008 01:19 PM
SiSpopu
Acura TL, RL & ZDX
Jul 7, 2006 09:33 AM
flir
Audio / Security / Video
Oct 28, 2005 02:11 AM
wizard920
Aug 22, 2004 03:22 PM
typerlover
Aug 23, 2001 06:51 PM
