Need help picking out turbo
Old Dec 5, 2008 | 02:31 PM
silkyjohnson#1hater's Avatar
Default Need help picking out turbo
Hey, how you guys doing. I need some advice from people who knows a thing or two about sizing and A/R etc as i dont know **** about that.
So here is my set up and you guys tell what you think.
Stock type r block 81mm
9-0-1 wiseco pistons
eagle rods
stock crank
cometic head gasket
stock type r head not ported or polished
skunk2 dual valve springs and ti retainers
pro series stage 1 cams
pro series cam gears
edelbrock manifold
bdl 70mm throtle body
top mount mani with 44mm tial waste gate
50mm tial bov
big intercooler have no idea what its called
and im looking to around 400hp on low boost and pump gas
and around 530hp on high boost with c16
please lmk what you guys think
Old Dec 6, 2008 | 08:55 AM
Turbocivic94's Avatar
T3/67mm turbo
Old Dec 6, 2008 | 09:04 AM
Schister66's Avatar
Man U FTW
There are a lot of turbos that can meet your goals. What is your budget and do you really plan to push 500+ on stock sleeves?
Old Dec 6, 2008 | 10:16 AM
yeah the car isnt my daily and on race gas i dont think it would be to bad to run stock sleeves until i can put together another block that is sleeved.
i mean i have 1200cc injectors so there should be enough fuel with proper tunning im thinking i can 500 to 530hp on c16.
I was looking at gt3582r and that thing was like 1385$ i just want to get less lag possible and im not so sure about that turbo anymore.
Old Dec 6, 2008 | 10:18 AM
OMG B16's Avatar
GT3076R
Nasty spool and capable of your power goals.
If you want room to grow with your future motor build then GT35R would work.
Old Dec 6, 2008 | 10:22 AM
miller's Avatar
I agree with the 3076r, it is a great turbo and is more then capable enough to meet your power goals. Like mentioned above the 35r is a great unit and will be able to support a little more in the future if you want more power.
Old Dec 6, 2008 | 11:41 AM
irishflame27's Avatar
Gt3076r ftw!
Old Dec 6, 2008 | 12:38 PM
Schister66's Avatar
Man U FTW
There are other options out there so dont just settle with what's popular. I've been slightly criticized for my suggestion of them, but many people have had great success with the Borg Warner S258. That turbo will make more power than you need and spools a hair slower than the GT30r. On the up side, it makes more power at higher PRs than the GT30r if you want to push it hard on race gas. It can make nearly 600whp on a great setup...
Old Dec 6, 2008 | 12:44 PM
TheShodan's Avatar
Moderator
My only concern for the smaller turbochargers that are being suggested (with the exception of the S258 under 30psi) is the fact that to get 500whp out of these, they need to be pushed rather hard into their range, which may indeed increase IAT temps. As a GT3076 and GT3037R owner, I understand the limits of these turbochargers for extended periods of time. 500whp and "quick spool" should not in any way be in the same sentence. If you're trying to get both out of one turbocharger, keep dreaming; one characteristic will take over the other. The S258 and S362 will still run over 1300 bucks, as well as the GT35R. I'd look again at the GT3540S and T67 for the same power levels at about $1000 or s, without the responsibility of the additional water / coolant lines that you'll need to run. Besides, you'll have enough trouble controlling the car on the street for over 400whp anyway, so "lag" is the least of your worries.
Old Dec 6, 2008 | 07:33 PM
2fastek's Avatar
what about a precison sc61, hows that compared to the s362?
Old Dec 6, 2008 | 09:52 PM
OMG B16's Avatar
Acouple of GT3076R dynos:
Engine: Sleeved/Fully Built B20vtec, Built B16a cylinder head, skunk2 stage 1 tuner series cams, edelbrock IM
Mods: AFI AFI Stage 2GT Kit (Gt3076r .82a/r), Double-Backdoor, Custom Endtanks, 3" thermal exhaust, no cat, RC 1000cc injectors, aeromotive a1000 fpr, walbro 255lph HP pump, 3 bar map sensor, AEM boost solenoid (boost by gear and rpm through hondata), Hondata s300
Tuning at 18psi on 93 octane and 25psi on c16:
Engine: GSR longblock, Tbone Built, Thermal Coated Arias 9:1 @ 81.5mm, Manley H-beams, ACL bearings. LS Crank, ATI super damper, skunk2 valvetrain, CTR cams, Edelbrock IM, 68mm tb
Set-up: Mainstream Performance A/C and P/S Topmount/DP, GT3076R (GT 4-bolt discharge, .82 a/r T3 turbine), Precision 600hp core, Modded Spoolin IC Piping ,Thermal Coating by Tbone (compressor,turbine,dp,manifold), 44mm tial, fast-turbo oil and coolant lines, S300 w/ boost control via perrin solenoid, precision 1000cc, custom obd2-obd1 harnessed resistor setup, gm 3bar
Tuning on 15psi on 93 octane:
- www.evans-tuning.com
Old Dec 6, 2008 | 10:22 PM
nowtype's Avatar
GT3076r, SC61, T3/T04e 60 trim with a .82 turbine housing, or a Holset HX35.
Old Dec 6, 2008 | 10:32 PM
JAY DEE EM YO's Avatar
Check out this turbo, http://www.nolimitmotorsport.com/prod/SCM-6031E its what I have and its has been pretty reliable, on car for 2 1/2 yrs about, 40k miles. No probs (yet) (knocking on wood)
Old Dec 7, 2008 | 02:35 AM
thanks guys for all the info and all the suggestions are great, im doing plenty of research on all the turbos you guys have suggested.
I want some room to grow just in case my motor breaks and i have to sleeve it. I dont want to have to buy a new turbo, but then again i want the a happy medium as i use the car now.
Old Dec 7, 2008 | 02:37 AM
sorry guys quik quest
should one walbro be fine for 400hp to 520hp or should i run 2
Old Dec 7, 2008 | 08:21 AM
TheShodan's Avatar
Moderator
One Pump will do the job fine.
And I was waiting from someone to put a Jeff Evans (super high) dyno of the GT3076R. As for your S362 vs SC61 question; the S362 is much more potent in the top end
Old Dec 7, 2008 | 12:18 PM
thanks bro
DA 4 Lyfe
Sep 4, 2011 03:22 AM
droe2001
Mar 5, 2011 08:41 PM
jeffnerette
Oct 4, 2009 02:48 PM
1992db2
May 28, 2009 05:26 PM
jdmef2er
Feb 18, 2008 03:27 AM
