anyone want to help me on my set-up?
Ok, so im building my first turbo build. Its going to be in a 92 GS-R, i was hopeing i could get a hand from you guys and tell me what you guys think about my set-up, maybe if im missing something or anything like that. Heres the list:
HEAD:
-JDM b16 head
-buddy club valve springs and retainers
-JDM ITR cams
-JDM ITR manifold portmatched with a blox 68mm throttle body
BLOCK:
-JDM b16 block
-JE 9:1 pistons, stock bore
-eagle rods
-arp studs ALL around
-blox blockguard
-cometic head gasket
TURBO KIT:
-turbonetics t4/t04e 60 trim turbo
-tial 38mm wastegate
-fab-works ramhorn manifold
-hks ssqv
-godspeed front mount intercooler
-blox boost controller
-3in. downpipe
-all turbo lines and fittings
-spoolin performance charge pipes
CRAP:
-delphi 550cc injectors
-walbro 255lph fuel pump
-hondata s200 with boost
-half size radiator
-autometer boost gauge
I think thats all i have...what do you guys think? any suggestions? parts im missing?
HEAD:
-JDM b16 head
-JDM ITR cams
BLOCK:
-JDM b16 block
-eagle rods
-blox blockguard
TURBO KIT:
-hks ssqv
-3in. downpipe
CRAP:
-half size radiator
Re: anyone want to help me on my set-up?
Personally I would go with oversized pistons and bore the block out. You're looking at saving maybe 150 bucks by not boring it out, and I believe that being able to setup your bore size perfectly to get the correct piston-to-wall clearance is a key factor in having a strong, healthy motor.
What power are you aiming for?
And yes, i've gotta agree with getting oversized pistons! Gotta be done if your building a forged engine for boost!
What about bearings? Don't forget about them whilst the engines open. I replaced the oil and water pump on mine too whilst it was in being worked on, just for peace of mind
so bigger injectors is something i will do forsure, those were going to be the ones i was going to use on stock internals and 8lbs of boost
Larger injectors and a fresh bore as mentioned. If you only plan on boosting it 8psi I'd upgrade to 10:1 compression. It'd be funner to drive and would be no problem for a good tuner.
nothing wrong with keeping it lower compression, something like 9.0:1 will be fine and you will have more margin for error if you wanna go bigger. Trust me, its something that will happen eventually
the block has a fresh hone, and all the rings have good clearences. So on my set up, what would be the most boost i can run? about 15lbs?
if it has a fresh hone.. but stock bore usually when its done they take 2 or 3 thousands off? or you do it your self? you could be safe running more then that with a good tune
raa Lcpl!!!
raa Lcpl!!!
well it was all done by a machine shop. i took the block in along with the parts, they honed it, sized the rings, checked clearences, balanzed the crank, and assembled it.
Does he really need an AM map sensor if he is only doing 8 psi?
