gsr running rich
Old Dec 5, 2008 | 11:48 AM
dtarvin's Avatar
Default gsr running rich
Was installing new header and saw my new cat is melting a bit. Checked spark plugs and they are also black, but I don't notice any black smoke. Would a tuneup fix this? Or are there other components I can check? There's no cel and I've installed only ram intake, skunk IM, and 2.5" exhaust.
Thx
Old Dec 5, 2008 | 06:36 PM
duefuss's Avatar
timing my friend timing
Old Dec 5, 2008 | 07:39 PM
miguel329's Avatar
mine did this!! all it was the rotor in dizzy screw fell out.... bought new cap and rotor problem solved!
Old Dec 5, 2008 | 09:14 PM
raidacaipo's Avatar
check spark plugs, distributor cap and rotor, and spark plug wires.. you can either change all 3 or check to see if they need to be replaced.. after that check ignition timing as well.. make sure your running 16 degrees btdc.. other stuff to check is like oil level and ecu.. stock ecu unless its tuned for the application
dcsports
Dec 7, 2008 06:54 PM
jason007
Apr 1, 2008 04:12 AM
JDMlyfestyle
25
Jan 20, 2004 01:11 PM
mattcalica
Dec 8, 2003 08:08 PM
Agent Daimon
Dec 19, 2002 09:46 PM
