h24 87-89mm oil in rad
Old Dec 5, 2008 | 09:03 AM
redh22alude's Avatar
Default h24 87-89mm oil in rad
so yeah im getting oil in the rad but not in the oil pan just curious what kind of head gasket you guys are running that have the h24 engine the motor has less then 500 miles on it i have arp head studs on this set-up it is also fully built and sleeved by ERL preformance the head gasket that is on the engine now is an oem honda and it was sent to golden eagle to be overbored/machined to 89mm so i am kind of lost on this is it possible that the oil cooler is bad which is causing the mix of oil and coolant any help or point in the right direction would be great thanks mike
Old Dec 8, 2008 | 01:03 PM
anybody help please!!!!
Old Dec 8, 2008 | 02:22 PM
vinuneuro's Avatar
Oil and coolant mixing is usually headgasket problem. I don't think I've ever heard of the oil cooler giving up in any car. I don't think an OEM headgasket would work in your situation since the cyl bore is 89mm.
Old Dec 8, 2008 | 04:09 PM
lude98SH's Avatar
my first guess would be headgasket also. Im not really sure how you would rule out the oil cooler though.
Old Dec 9, 2008 | 02:32 PM
Scheizty's Avatar
Volume (cm^3)= Pi*radius^2*height*4(cylinders)
3.14*(8.9cm/2)^2*(9.07cm)*4 = 2256cc = 2.3 liters
A 2mm overbore does not make your motor a 2.4L.
The route you should take is to remove the oil cooler and see if it will hold air pressure through the coolant line.
Old Dec 15, 2008 | 02:08 PM
bump anybody else have anything
Old Dec 29, 2008 | 10:03 AM
BlkNPnkH22aCRX's Avatar
Default Re: h24 87-89mm oil in rad
I would say headgasket as i have already told you...
Old Dec 29, 2008 | 08:09 PM
VtecFreePrelude's Avatar
do a pressure test on the coolant system. it should hold at the pressure you put it on and if it drops then you can worry about something being bad.
also what oil cooler are you talking about? my h22 swap is just fine and i dont have an oil cooler anywhere. the old auto h23 had one for the trans but not the engine.
is it an aftermarket one or did you do something different with the radiator?
and also by saying "oil in the radiator but not in the oil pan" is that supposed to be an oil/coolant mix in the radiator but not in the oil pan?
Old Dec 29, 2008 | 09:56 PM
mattsnooz's Avatar
what? no oil cooler?. Its under the water pipe at the back of the block. Its what your oil filter screws into!
Old Dec 30, 2008 | 09:32 AM
ya thats my bad. i was taking oil cooler as an externally mounted radiatior style oil cooler.
Dat1BVtecN
Mar 17, 2007 09:17 PM
gdh8su
Nov 10, 2006 05:36 PM
b16 matt
Sep 23, 2004 11:19 AM
G3gsr
May 20, 2003 06:17 PM
