strange problem.. '97 Civic
I just took my B16B out, replaced it with a D16Z6 in my '97 coupe. Used PW:JDM jumper harnesses for both the distributor and ECU, used the OBD2 injectors (same as P28s, with OBD2 clips), and re-wired the alternator accordingly.
When I try to crank the car, it just turns over -- never starts. Checked spark, it's good. Checked all grounds -- they're good.
When I turn the car to "ON" the relay clicks once. The fuel pump does not prime. The CEL does not come on. When I turn the car back off, the relay clicks again.
I though it may be the fuel pump, replaced it with an operating one -- same problems.
Any clues?
changed main relay today, still same problem.
And now a new issue has arisen -- no power. For the past 2 days i've had plenty of battery power to try start the car. Today it died, so i try jumping it off -- still no power even with the other vehicle running and the jumper cables attached.
Thanks for any help!
Any clues?
I've had similar problems but never was a fan of jumper harnesses. Make sure your Engine harness is cut free, and check the fuses it could be something as simple as a blown fuse for the fuel pump. Start with the simple things before you think dramatically. I did the mistake of fixing all the unnecessary things and it turned out that I needed an Engine harness and push the fuse for the fuel pump in. Stress can do that to you, but Good luck.
tegguy1987
Nov 23, 2018 02:39 PM
greyEG
May 26, 2013 07:16 PM
slowpokecivic
Jul 26, 2012 07:37 PM
endless_pain
12
Jun 7, 2005 05:52 AM
