strange problem.. '97 Civic
I just took my B16B out, replaced it with a D16Z6 in my '97 coupe. Used PW:JDM jumper harnesses for both the distributor and ECU, used the OBD2 injectors (same as P28s, with OBD2 clips), and re-wired the alternator accordingly.
When I try to crank the car, it just turns over -- never starts. Checked spark, it's good. Checked all grounds -- they're good.
When I turn the car to "ON" the relay clicks once. The fuel pump does not prime. The CEL does not come on. When I turn the car back off, the relay clicks again.
I though it may be the fuel pump, replaced it with an operating one -- same problems.
Any clues?
changed main relay today, still same problem.
And now a new issue has arisen -- no power. For the past 2 days i've had plenty of battery power to try start the car. Today it died, so i try jumping it off -- still no power even with the other vehicle running and the jumper cables attached.
Thanks for any help!
Any clues?
It could just be coincidental that the battery might have just took a crap on you. Also, for not hearing the fuel pump priming, did you check the what I think is a 10A fuse under the dash for the fuel pump?
I've had similar problems but never was a fan of jumper harnesses. Make sure your Engine harness is cut free, and check the fuses it could be something as simple as a blown fuse for the fuel pump. Start with the simple things before you think dramatically. I did the mistake of fixing all the unnecessary things and it turned out that I needed an Engine harness and push the fuse for the fuel pump in. Stress can do that to you, but Good luck.
tegguy1987
11-23-2018 02:39 PM
greyEG
05-26-2013 07:16 PM
slowpokecivic
07-26-2012 07:37 PM
endless_pain
12
06-07-2005 05:52 AM
