Think I blew an exhaust gasket how can I tell?
Old Aug 2, 2002 | 06:29 AM
DC2R714's Avatar
Default Think I blew an exhaust gasket how can I tell?
I think I blew my gasket from my turbo connecting to the mani. How can I tell. It looks like it might be split from the outside. My maintenance light is on now but the car still runs fine.
Old Aug 2, 2002 | 07:55 AM
CovertFI's Avatar
Default Re: Think I blew an exhaust gasket how can I tell? (DC2R714)
you will see your exhaust coming out were evert the gasket is leaking. or when the mani is cold start your engine up and put your had in the area. you can only do this for about a min or 2 because then it will be too hot.
Old Aug 2, 2002 | 11:08 AM
HybridKOOP's Avatar
EDIT: I didn't read carefully... I thought he said headgasket.
[Modified by HybridKOOP, 8:21 PM 8/2/2002]
Old Aug 2, 2002 | 11:25 AM
M.A.R.C.'s Avatar
Default Re: Think I blew an exhaust gasket how can I tell? (HybridKOOP)
he meant the exhaust/turbo manifold gasket
Old Aug 2, 2002 | 10:41 PM
racerxadam's Avatar
A lot of guys on here don't even run a gasket for that joint, so even if its blown i wouldn't worry about it. eventually carbon deposits will build up enough to stop the leak if there is one. If you want a new gasket go to http://www.roadraceengineering.com/f...andgaskets.htm
didyouhearthat
Nov 10, 2013 08:11 PM
lando griffin
Jan 15, 2009 03:51 PM
jonnybadboi9
May 8, 2008 06:16 PM
1slwEK
Feb 15, 2008 07:52 PM
