Exhaust leak...
Old Jan 14, 2009 | 04:24 PM
lando griffin's Avatar
Default Exhaust leak...
I just got a new exhaust and it's leaking at one spot (where the midpipe meets the resonator). On a cold start, I can see a little bit of water dripping out. Bolts are as tight as I can get them and the gasket is on.
Is there anything I can do? Can the gasket only go one way? I tried flipping it around and it sat the same it seems.
Old Jan 15, 2009 | 12:15 PM
ddd4114's Avatar
Default Re: Exhaust leak...
So it's leaking between two flanges? You can try using copper spray on the gasket.
Old Jan 15, 2009 | 03:51 PM
Yeah. I just put some of the ultra high-heat silcone copper gasket maker on it along with the gasket. Wasn't sure how much to put, so i just put a thin layer between the two.
Gotta wait 24hrs or more until I can check if its still leaking.
tekstyle
Oct 22, 2009 06:54 PM
jonnybadboi9
May 8, 2008 06:16 PM
DC2R714
Aug 2, 2002 10:41 PM
