eletric windows (help) integra R
hello guys
i have been haveing trouble with my windows they keeping jumping when i press the button up or down so i.
i took my door cards off and checked the glass is lined up probley on the runners they are, and greased all moveing parts. They are abit better but when they go down half way they make a realy loud squeek could anyone help, and sometimes the drivers side still jumps abit?
many thanks jay
many thanks jay
Why is this the wrong place?.....He owns a 98 Honda ITR in the UK....or did I miss something?
If the window is "jumping" when you roll it up or down you might have broken teeth on the window regulator gear. The most common reason is if someone tries to break into a car by prying the window down. Most Honda p/w motors have 4 revolutions of the gear to go up or down.......if the motor only "jumps" once that most likely is not the problem...If it happens a few times it "could be"
If might also only be the window sticking in the tracks or the seals. Get some silicone spray (not grease or WD40) and spray it in the seal where the glass rides up and done.
Hope that helps
Matt
Hope that helps
Matt
frank358fr
Honda Civic (2006 - 2015)
Apr 23, 2009 05:54 AM
