wire help
Old Dec 4, 2008 | 12:34 PM
cashkeith's Avatar
Default wire help
hey guys i just did a wire tuck for the last week today i hooked everything up i just put the battery in just to see if everything worked befor i put the dash in and i dont have the fuel lines hooked up so i dont wanna try to start bc shot fuel out when i turned the key like it should
but what im asking is should the turn signals work like the lights and all work DO I NEED THE CLUSTER IN TO HAVE THEM WORK
Old Dec 4, 2008 | 12:38 PM
teamvirus's Avatar
My car breaks a lot!
put the cluster in and then bam! you will know
Old Dec 4, 2008 | 12:40 PM
cashkeith's Avatar
just thought id ask befor i took it out of the dash GUY
Old Dec 4, 2008 | 12:55 PM
cashkeith's Avatar
pleae help?
Old Dec 4, 2008 | 01:00 PM
jdmdikk's Avatar
you shouldnt need the cluster in ,,in order to have your headlights or corner lights work..check your connections or blown fusses
wrenchez81's Avatar
what year make/model?
Old Dec 4, 2008 | 01:55 PM
cashkeith's Avatar
hey no the head lights and corners work just not the turn signals but i think i do need the cluster in for them to work
its a eg 2 door
Old Dec 4, 2008 | 07:22 PM
ketchup!'s Avatar
do work son!
Old Dec 4, 2008 | 07:27 PM
rsnupt82's Avatar
the lights should work without te lcluster being in... just watch out with spewing gas in your engine bay. have someone check outside when u open the ignition for a split second.
Old Dec 4, 2008 | 07:59 PM
EGhatch87's Avatar
you need your hazzard lights switch pluged(the one you push 4 hazzards) in in order for blinker to work and key on ON
Old Dec 4, 2008 | 08:06 PM
MrFresh's Avatar
Exactly.
tonymx18
Jun 22, 2025 07:14 AM
miked123
Aug 19, 2013 12:33 PM
Tyla12
May 28, 2010 09:00 AM
mynameisMUDD
12
Jan 16, 2010 02:10 PM
Xathine
19
Feb 4, 2009 04:27 PM
