my climate control dont light up at night anyone know a fix?
Old Dec 4, 2008 | 09:46 AM
king29's Avatar
Icon3 my climate control dont light up at night anyone know a fix?
ok, so im gonna lay it out as simple as possible
i drive a eg sedan 93 dx, i dont know if that makes a difference
but all my dash lights work, my dimmer switch works, the heat, and cold work on my climate control, even the lights too the little top buttons turn on
BUT!.....at night i cant see SQUAT!! cause idk the lights that turn on the background dont light up
could they be just burned out?? or is their an electrical problem(not really sure since the cc works and all)
help, and what size bulbs do i need to buy to replace
ty
Old Dec 4, 2008 | 09:59 AM
94EG8's Avatar
Seagull Management
Theres only 2 bulbs for the backlighting in the climate control and I have seen both bulbs burn out before. So thats my guess. Not sure what size the bulbs are though.
Old Dec 4, 2008 | 10:23 AM
boosted ej8's Avatar
Have you checked your fuses before you go ripping your dash out?
I had my cluster fuse blow once
everything worked just no light
I would check a dollar fuse before I pulled my dash apart and swapped light bulbs
let us know when you check man
I know it can be a PITA
Old Dec 4, 2008 | 11:39 AM
king29's Avatar
Default hmmm
ok some guy was telling me their the size 74 at autozone for a pack of 2, so im gonna try that, but FIRST im gonna check my fuses
anyone know which fuse it will be located under?
Old Dec 4, 2008 | 12:02 PM
Mrmatt3465's Avatar
Check the fuse map. I think there is also a topic that is a DIY for amber lights in a USDM cluster ad climate control. He used LEDs and they looked real nice.
Old Dec 4, 2008 | 12:22 PM
yea look on the fuse map on the inside of the fuse cover
Old Dec 4, 2008 | 12:29 PM
Jas9848's Avatar
it's probably your bulbs. yes they are #74's and can be purchased at your local parts store. here's a good write-up for replacement. http://www.emotors.ca/Articles/116.aspx
Old Dec 4, 2008 | 02:40 PM
xloserxdrummerx's Avatar
I don't know if this will help, since you said your dash lights work, but on my '92 civic the dash lights and climate control lights wouldn't turn on with the headlights. Long story short, the dimmer switch had gone bad. Like I said, may not be your problem but I thought I'd put in my two cents.
Old Dec 4, 2008 | 03:21 PM
trustdestruction's Avatar
I agree, it's probably the bulbs. If it were the dimmer switch, your entire dash wouldn't light up.
aznlaoboi315
Feb 17, 2008 08:43 PM
mr0lg
May 16, 2005 06:02 PM
dhammer
Feb 24, 2004 10:51 AM
2muchPSI
Jan 11, 2003 10:18 AM
