ecu?
Old Dec 4, 2008 | 08:15 AM
xft's Avatar
xft
Default ecu?
i am in the final stages of my Ek swap with a gsr motor and im startin to wounder about my ECU i bought the OBD1 jumper harness and was wounder if i could use a OBD1 chipped P72 or do i have to use the P28
also anyone no if i have to swap out my hold throttle cable from the civic to my integras
Old Dec 4, 2008 | 08:18 AM
egvtec's Avatar
you can use a chipped P28, or an obd1 P72 with the conversion harness. You dont need to run a chipped P72 to properly run that motor, assuming its n/a.
Old Dec 4, 2008 | 08:20 AM
scspeed's Avatar
Yes you should be fine using that ecu. It really shouldnt make a difference...And about the throttle cable. I belive that the stock civic one would be too short...your just going to have to put it in and see. Maby you can rig up a braket to make it work or something..
Old Dec 4, 2008 | 08:24 AM
xft's Avatar
xft
thanx guys i just didnt wanna hook up my ecu and run my car to lean or anythin like that im kinda dont this hole swap off the top of my head and from ppl on here so thanks again for the advice
Old Dec 4, 2008 | 08:26 AM
egvtec's Avatar
just dont use a stock p28, either run P72 or a chipped P28 with a P72 program, and watch those chipped p28s on ebay some run your motor richer than bill gates
Old Dec 4, 2008 | 08:33 AM
xft's Avatar
xft
ya im just ganna run my p72 with the skunk2 chip so i dont run into any issues with buyin another ecu or anythin like that
Old Dec 4, 2008 | 08:54 AM
ham's Avatar
ham
dont forget about the secondary butterflies... you would need a p72 to properly run them.
Old Dec 4, 2008 | 09:17 AM
scspeed's Avatar
or jst run a scunk 2 mani hehe :tup:
Old Dec 4, 2008 | 09:18 AM
xft's Avatar
xft
i have a skunk 2 manifold so i dont have to worry about that
Old Dec 4, 2008 | 11:07 AM
teamvirus's Avatar
My car breaks a lot!
if your worried about it then get it turned, if you have the money do it right :D
Old Dec 4, 2008 | 12:03 PM
ham's Avatar
ham
oh then you can use either ecu. just make sure the chip has a p72 map or get it tuned.
to your other question: I didnt have to swap throttle cables when i did the same swap. it put a very slight kink in the cable, but didnt cause it to stick or anything. since you have a skunk2 manifold, i believe it has the mouting bolts for a b16 throttle cable bracket?
Supersonicbug
Engine Management and Tuning
Jul 9, 2010 11:54 AM
b18c_Ek101
Mar 12, 2010 12:56 PM
dynimitejack
Dec 31, 2008 09:37 PM
Mhollaek9
Jun 23, 2007 07:21 PM
pchan
Dec 17, 2006 11:27 AM
