ecu?
ecu?
i am in the final stages of my Ek swap with a gsr motor and im startin to wounder about my ECU i bought the OBD1 jumper harness and was wounder if i could use a OBD1 chipped P72 or do i have to use the P28
also anyone no if i have to swap out my hold throttle cable from the civic to my integras
Yes you should be fine using that ecu. It really shouldnt make a difference...And about the throttle cable. I belive that the stock civic one would be too short...your just going to have to put it in and see. Maby you can rig up a braket to make it work or something..
thanx guys i just didnt wanna hook up my ecu and run my car to lean or anythin like that im kinda dont this hole swap off the top of my head and from ppl on here so thanks again for the advice
oh then you can use either ecu. just make sure the chip has a p72 map or get it tuned.
to your other question: I didnt have to swap throttle cables when i did the same swap. it put a very slight kink in the cable, but didnt cause it to stick or anything. since you have a skunk2 manifold, i believe it has the mouting bolts for a b16 throttle cable bracket?
