Quick rocker panel Question
Old Dec 3, 2008 | 05:46 PM
Mikes2000civicsi's Avatar
Default Quick rocker panel Question
hey guys,wondering whether a rocker panel for a 97 sedan fit a coupe?,friend needs a replacement panel but the only 1 i can find online are sedan and hatchback
Old Dec 3, 2008 | 07:23 PM
someones gotta know
Old Dec 4, 2008 | 12:42 PM
bump
Old Dec 4, 2008 | 12:59 PM
98greensi's Avatar
depends one how far it goes up, from all the ones i've seen go into doors. so my answer would be no, but i have never seen one for a honda, check your local auto store
Old Dec 4, 2008 | 01:52 PM
pkdog167's Avatar
which part of the car is referred to rocker panel?
Edit: Is it referring to the quarter panel or the side skirt?
If you are referring to the side skirt, then the hatchback one is the same as the coupe one.
if you are referring to the quarter panel, then you need to cut the hatchback one in and weld it on to the coupe one because most part of the hatchback quarter panel is the same as coupe one.
The 97 civic sedan have totally different quarter panel and side skirt.
Hope this help.
Old Dec 4, 2008 | 07:10 PM
censurebush's Avatar
From: everything for everyone, and nothing for ourselves
that's funny.
the hatchback and coupe rocker panel moldings are the same. you can buy the sedan skirts and cut them if you really want to.
Old Dec 4, 2008 | 07:14 PM
sniggler316's Avatar
Originally Posted by censurebush
that's funny.
I think he means the moulding or the actual rocker panel. Either way, no, the sedan is different.
Old Dec 4, 2008 | 07:43 PM
rsnupt82's Avatar
uh... i think they might fit.... find some ones sedan on the street and break out a ruler.
Old Dec 4, 2008 | 07:50 PM
well this is for a friend so i guess a hatchback will work,its the part the side skirt connects to the metal part incase some of you are wondering,thanks h-t
Old Dec 5, 2008 | 08:36 AM
pkdog167's Avatar
hatchback one is the same, the sedan one has the same length, however the side goes out differently + u need to cut the rear top part of the side skirt so it fits.
Snap5
Apr 14, 2021 10:26 AM
OldSchoolAce
Paint and Body
May 27, 2014 04:17 PM
blackoutt
May 31, 2010 03:12 PM
baozer
Oct 11, 2006 05:41 PM
getzy3
Dec 29, 2004 10:05 AM
