Quick rocker panel Question
hey guys,wondering whether a rocker panel for a 97 sedan fit a coupe?,friend needs a replacement panel but the only 1 i can find online are sedan and hatchback
depends one how far it goes up, from all the ones i've seen go into doors. so my answer would be no, but i have never seen one for a honda, check your local auto store
which part of the car is referred to rocker panel?
Edit: Is it referring to the quarter panel or the side skirt?
If you are referring to the side skirt, then the hatchback one is the same as the coupe one.
if you are referring to the quarter panel, then you need to cut the hatchback one in and weld it on to the coupe one because most part of the hatchback quarter panel is the same as coupe one.
The 97 civic sedan have totally different quarter panel and side skirt.
Hope this help.
Hope this help.
Location: everything for everyone, and nothing for ourselves
well this is for a friend so i guess a hatchback will work,its the part the side skirt connects to the metal part incase some of you are wondering,thanks h-t
hatchback one is the same, the sedan one has the same length, however the side goes out differently + u need to cut the rear top part of the side skirt so it fits.
Snap5
04-14-2021 10:26 AM
baozer
10-11-2006 05:41 PM
getzy3
12-29-2004 10:05 AM
