Sidekick LX BRAND NEW IN BOX WITH ALOT EXTRA! T3T4 TURBO!
I have a brand new sidekick lx that has not been open and still sealed in its box. Comes with
car charger
x2 Carrying cases
sidekick black housing
protective screen for the lcd screen
2gb sd card
54mb sd card
usb port
300.00 for everything. No trades, no car parts, FIRM
T3T4 (only problem is there is a 2 inch bolt stuck on the exhaust downpipe sided that can be easily taken out )turbo specs here
T3/ T4 HYBRID TURBO CHARGER
INLET: 3"
OUTLET: 2"
BEARING TYPE: WET FLOAT BEARINGS
OIL INLET: 1/8 NPT
MAX PSI CAPACITY 27PSI
COMPRESSOR .50 AR COMPRESSOR
TURBINE: .63 AR TURBINE
COMPRESSOR WHEEL: .57 T COMPRESSOR WHEEL
EXDUCER: 3"
INDUCER: 2"
TURBINE WHEEL .63 AR TURBINE WHEEL
EXDUCER: 2.2"
INDUCER: 2.58"
FLANGE TYPE: T3 FLANGE
DOWN PIPE FLANGE TYPE: 5 BOLT STANDARD (.58)
MAX HP: 350-375HP
60.00
car charger
x2 Carrying cases
2gb sd card
54mb sd card
usb port
INLET: 3"
OUTLET: 2"
OIL INLET: 1/8 NPT
EXDUCER: 3"
INDUCER: 2"
EXDUCER: 2.2"
INDUCER: 2.58"
MAX HP: 350-375HP
60.00
B00STFREAKS
Nov 16, 2005 05:22 PM
