Need your help guys.
Old Dec 3, 2008 | 07:56 AM
chevellion's Avatar
Icon2 Need your help guys.
So I finished swapping my engine yesterday and began pouring coolant in the radiator.
All is going great until it begins leaking. A small steady flow of coolant begins leaking out between the head and intake manifold.
Should I replace the gasket? Any other ideas?
Old Dec 3, 2008 | 08:05 AM
KING PIN's Avatar
umm yeah get a new gasket
Old Dec 3, 2008 | 09:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
new gasket, and the IM may not have been tightened down enough.
And trust me when I say, it's a HUGE PITA if the engine is still in the car. At least on the dual-runner intake manifold w/ OBD1 stock oil cooler it is.
Old Dec 3, 2008 | 10:36 AM
chevellion's Avatar
Old Dec 3, 2008 | 01:02 PM
Community Builder
damn is there even a gasket on there? I can't see one. Did you put a new one on there when you installed that IM?
Old Dec 3, 2008 | 01:04 PM
rebar71's Avatar
x2
Old Dec 3, 2008 | 01:05 PM
Slain's Avatar
is that the coolant bleeder valve right above the leak ? i'd make sure that is tightened down.
nevermind just watched the video.. intake mani problems leaks are a pain in the ***
Old Dec 3, 2008 | 01:33 PM
chevellion's Avatar
Yeah there is a gasket on there...
I'll pull it off tomorrow, replace the gasket, and put some sealant on there as well.
Thanks a lot guys. Can't believe I swapped an engine lol.
Old Dec 4, 2008 | 03:35 AM
mac_24_seven's Avatar
Good job man. Keep us updated on t3h progress on your first engine swap!!
Old Dec 4, 2008 | 06:50 AM
Community Builder
I don't think you're supposed to use any kind of sealant on the IM gasket. That could possibly cause more leaks, be it coolant or vacuum leaks.
Old Dec 4, 2008 | 07:21 AM
chevellion's Avatar
Alright. Terrance suggested to scrape the excess residue, old sealant off to make the seal flush for the new gasket. I shall to this.
Old Dec 4, 2008 | 07:29 AM
Community Builder
Did you not scrape off the old gasket and put on a new gasket when installing the IM? That's a must, especially if that old@$$ original OEM cork gasket was still on there.
smg0248
Jan 15, 2019 08:02 PM
elmejor
Jul 17, 2009 03:45 PM
stwano
Jun 27, 2006 02:50 AM
Jowee
Nov 18, 2005 10:07 AM
Kevin
May 22, 2002 11:18 PM
