fludded motor
Old Dec 2, 2008 | 09:18 PM
vteck1ck's Avatar
Default fludded motor
My motor is fludded need advice.
Old Dec 2, 2008 | 09:22 PM
vteck1ck's Avatar
Default clutch slips
Wuts up, so oil is leakin from my tranny and now the clutch slips a lot when the clutch has warmed up, so wut can I do.
Old Dec 2, 2008 | 09:24 PM
Spool This's Avatar
only thing i can give is a theory for this, never attempted but makes sense...pull the fuel fuse and keep turning it over...LOL maybe? its funny too cause i replaced a coil and was slightly flooded but cleared up after i just rev that bitch a couple times...
Old Dec 2, 2008 | 09:40 PM
EGfosho's Avatar
OG Tech
If the engine is flooded, you can take the spark plugs out and take one of those spay nozzles and put the tube in where you took the spark plugs out and spray the gas or water out. If the clutch is slipping, you probably need a new clutch, usually when it slips it is because the clutch has no grip.
Old Dec 2, 2008 | 09:52 PM
vteck1ck's Avatar
The question about the clutch slipping ended up as a reply, I don't kno how but, the clutch is a few months old then a lot of oil started leakin then the clutch started slippin.
Old Dec 3, 2008 | 12:02 AM
ek25's Avatar
take all of the spark plugs out, pull the fuel pump fuse and crank the car to get the water out, get new plugs, change oil, and check your airfilter
Old Dec 3, 2008 | 12:27 AM
TheJGB3's Avatar
If your clutch is shot because it has oil on it YOUR REAR MAIN SEAL IS LEAKING. Replace the rear main seal and clutch to resolve the issue.
Old Dec 3, 2008 | 12:31 AM
halocore's Avatar
i would recommend that you pump has much liquild out as possible to reduce the chances of hydro-locking
Old Dec 3, 2008 | 02:38 AM
wrenchez81's Avatar
you could also just unplug the injectors and pull each plug then crank it aswell...
Old Dec 3, 2008 | 11:47 AM
ek25's Avatar
yap rear - main seal + new clutch, resurface flywheel
Old Dec 3, 2008 | 12:17 PM
SOHC_4dr's Avatar
hold on people. what car is it first? you can do a clear flood mode by holding the gas pedal to the floor and cranking the motor. holding the pedal down shuts off the injectors on a fuel injected engine.
do this also
Old Dec 3, 2008 | 12:22 PM
CivicSi95's Avatar
i love how you spell "flooded." education ftw
Old Dec 5, 2008 | 07:36 AM
vteck1ck's Avatar
It's a d16z6
Nicaraguense13
Mar 13, 2007 04:36 AM
dyases
Nov 30, 2003 09:25 PM
genop
Jan 12, 2003 07:45 PM
ALF
Nov 30, 2001 09:58 PM
