Driver side window won't go down
Old Dec 2, 2008 | 02:48 PM
chatman_55's Avatar
Default Driver side window won't go down
It's been a problem for a little while that i would have to hit my switch to get the window to work so i figured the switch was broken about 2 weeks ago it completely stopped working so time to start searching for a new switch, i found one on CL and put it on.... still doesn't work! Idk how to check if the motor for the window is just dead. is there anything else that could be wrong other then the motor? how can i tell if it is the motor? where is the motor? and how much is a new one going to run me?
Old Dec 2, 2008 | 03:33 PM
TunerN00b's Avatar
When my window first "failed", it was simply the track that hte rear side of the widow slides in being dirty. Cleaning out that track restored operation. Check that before continuing.
The 2nd time my driver window went out, it ended up being an electrical short, probably from getting the switch wet repeatedly (smoking while driving in the rain, and autocross w/ windows down in the rain), but the short fried the switch, the regulator, and the motor. Cost was nearly $900 at the dealership for all 3 parts, labor, and tax. There was a burnt wire found, the fuse was intact, and all 3 electrical parts were tested individually and found to be dead. Hopefully that isn't the case for you.
Old Dec 2, 2008 | 04:55 PM
chatman_55's Avatar
when it was just the track being dirty did it make any noises like it was trying to go down? mine literally doesn't do anything anymore. and for a little while it wasn't automatically going down after you just push the button but it was going automatically up.
Old Dec 2, 2008 | 06:25 PM
TunerN00b's Avatar
Made noises while moving slowly, when only somewhat dirty. Sound got louder and window slower over time. Stopped making any noise at all when the motor couldn't move the window (I thought I killed the motor pushing the window through the dirty track at first). Cleaned the track, sounded and operated normally, went on with life.
It stayed fine for 2 years after that, with no cleaning again. Then, poof, completely dead with fried electrical randomly one day.
Old Dec 2, 2008 | 06:28 PM
chatman_55's Avatar
ok sorry to ask this one but im extremely ne to doing my own stuff to my car but how should i go about cleaning the track?
Old Dec 2, 2008 | 09:23 PM
chatman_55's Avatar
sorry im stupid and need to bump it, really want to fix this in the morning so i need the info.
Old Dec 5, 2008 | 11:47 AM
Pwrdbyhonda99's Avatar
yeah I'm having the same problem and would also like to know the best way to clean out the track
Old Dec 6, 2008 | 12:09 PM
pooorman's type-r's Avatar
i have a driver side window regulator, if you need it. of course there's a price on it. LMK if you want it
Bayhustle81
Aug 31, 2009 01:44 AM
MtbikingKing
May 5, 2006 09:27 PM
Edgemingsr
Jun 2, 2004 10:08 PM
dskny
Mar 26, 2003 04:23 PM
