double valve spring
Old Dec 2, 2008 | 01:56 PM
avotegra's Avatar
Default double valve spring
i have two gsr head with everything. can i use the double valve spring on the intake side of each head put them on just one head. so both side have double valve spring. will that help a lilo bit.
Old Dec 2, 2008 | 03:52 PM
avotegra's Avatar
can i rev a lilo bit higher is what i've mean...
Old Dec 2, 2008 | 04:57 PM
got wide's Avatar
see if you can find the specs for them (installed height, spring rate, etc..) and compare the specs to some different aftermarket setups and see if they compare. if they do, try it out.
Old Dec 3, 2008 | 12:07 PM
avotegra's Avatar
anyone ever try this....if have please answer....
Old Dec 3, 2008 | 12:13 PM
LA_HONDAS's Avatar
what are you trying to say?
what kind/brand of springs your talking about?
why you want to change just the intake side?
you more info so we can help
Old Dec 3, 2008 | 12:28 PM
HiProfile's Avatar
Unless you have the worst-profile of worn-down B16 cams for the exhaust, I wouldn't do it due to possibly floating an exhaust valve. If you have bigger cams, its very likely to cause an issue.
So to sum it up, weak cams that won't float valves won't make power after stock redline, and big cams that will make power will probably float (or even drop) a valve. You're damned either way, so do the right thing and get a full new set of springs.
Old Dec 3, 2008 | 12:34 PM
avotegra's Avatar
What iam trying to say. A gsr head has double spring on the intake side, and i've happen to have two gsr head. iam trying to use the double spring on the intake side of the head swap with the single spring on the exhaust side cam. then both side of the cam has double valve spring. question is? will that be the same as buying a double valve spring kit.
Old Dec 3, 2008 | 12:35 PM
avotegra's Avatar
this is on stock cam
Throwdown
Mar 5, 2019 08:41 AM
jwaked
Oct 17, 2003 01:13 PM
jrcrx
May 30, 2002 06:46 PM
ic108
Feb 14, 2002 04:49 PM
ninjaman
Jul 17, 2001 01:43 PM
