OBD2A engine harness in OBD2B
Old Dec 1, 2008 | 09:06 PM
Zero Signal's Avatar
Icon2 OBD2A engine harness in OBD2B
What needs to be changed on an OBD2A (96-99) engine harness to get it to work on an OBD2B (00-01) main harness? Engine and main harness are both integra, Thanks.
Old Dec 1, 2008 | 09:53 PM
shotenITR's Avatar
I think the connecting plug at the shock tower is different. I may be wrong, but I know this was the case on my em1. Had to buy obd2b engine and interior harnesses to keep it factory clean. Or you can cut and solder or repin a plug.
Old Dec 2, 2008 | 07:23 AM
94EG8's Avatar
Seagull Management
Nothing, its not like the civics, The engine harness remained the same from '96 - '01 The interior harness did change, shock tower plugs remained the same. (note integra also did not switch to the smaller style distributor plug like the D-series civics)
Old Dec 2, 2008 | 08:10 PM
What about the wiring where the distributor is I have 8 wires on the engine harness side and 9 on the distributor plug?
Old Dec 3, 2008 | 02:44 PM
bump for ? above
Old Dec 4, 2008 | 03:52 PM
94EG8's Avatar
Seagull Management
The missing wire is for the tach signal. Depin A19 at the ECU and splice a wire onto it and connect it to the blue wire comming from the distributor that doesn't go anywhere on the engine harness side of the plug.
Old Dec 6, 2008 | 11:51 PM
my tach works tho
Old Dec 7, 2008 | 11:53 PM
bump
Old Dec 8, 2008 | 06:11 AM
94EG8's Avatar
Seagull Management
my tach works tho
Somewhat misread that, if you are using an OBD2B ECU and main (vehicle/chassis) harness you will not need to rewire anything.
Old Dec 9, 2008 | 12:04 AM
ok cool thanks just making sure that wire didn't go to anything.
Yodi71
Dec 15, 2013 07:57 PM
D_koschak
Mar 20, 2012 11:01 PM
honda-mini
Apr 14, 2007 04:58 AM
Keith P
Jun 12, 2005 04:33 PM
RotiEatter
Jan 11, 2005 11:46 AM
