Suspension & Brakes Theory, alignment, spring rates....
Ground Control Spring Rate Confusion??
Old Nov 30, 2008 | 07:46 PM
jbuck2kcivic's Avatar
Default Ground Control Spring Rate Confusion??
Ok these are the spring rates I am buying:
Front:
200.64.58
Rear:
204619-1
I am trying to figure out what these are in American units. Thanks in advance!
Old Nov 30, 2008 | 08:36 PM
Tyson's Avatar
Since the GC springs are just Eibach springs made to GC's specs you can discern the spring rate and dimensions. Eibach labels their springs in the following order:
Length . Diameter . Spring Rate
They may come labeled in either English (inchesx100, inchesx100, lbs/inch) units or Metric units (mm, mm, N/m)
The conversion from Metric to English is (/25.4, /25.4, x5.7)
200.64.58
8" , 2.5" , 330 lb/inch
the rear number is a batch number. you have the wrong set of numbers.
Old Dec 1, 2008 | 01:47 AM
Fresh'86's Avatar
200.64.58
Wow excellent post, I always wondered what the label on the spring was. Thanks.
Old Dec 1, 2008 | 08:09 AM
200.64.58
Thanks for the help. He sent me pics of the springs, and those are the number off it. I will try and get the correct numbers for the rear and post them up.
Old Dec 1, 2008 | 10:48 AM
Facedagod's Avatar
I'm a bit of a noob when it comes down to this but what does the 8 inch and 2.5 inch represent
Old Dec 1, 2008 | 11:57 AM
Tyson's Avatar
eibach race springs have different lengths, inner diameters and spring rates.
they WILL NOT work on stock shocks without a proper perch, like ground control kits, or a threaded body shock that has its own perch.
Old Dec 1, 2008 | 04:20 PM
Ok so the rear springs are labeled as follows:
180.64.44
American units please. Thanks
Old Dec 1, 2008 | 05:11 PM
Tyson's Avatar
180.64.44
did you ever learn to use a calculator? please?
Old Dec 2, 2008 | 04:38 AM
unusual71's Avatar
^^yeah he couldnt have made it any simpler for you. The burden of knowledge is a heavy one, eh Tyson?
Old Dec 2, 2008 | 09:03 AM
Oops I didn't see that conversion factor mentioned above. It's all good now.
Old Aug 19, 2009 | 08:35 PM
eklum's Avatar
Default Re: Ground Control Spring Rate Confusion??
this is awesome .
Old Aug 19, 2009 | 10:24 PM
racebum's Avatar
if you feel even lazier still you can type the part number into google. 9 out of 10 times it pulls a post somewhere asking the same question about a spring rate number.
Naturally Aspirated
Sep 21, 2004 06:23 PM
danmanh22
May 28, 2004 09:02 PM
96 SOHC VTEC
Mar 30, 2003 10:17 AM
Doctor CorteZ
Feb 27, 2002 06:07 PM
InstantRamen
Aug 10, 2001 10:02 PM
