Exhaut ideas
Old Nov 30, 2008 | 07:29 PM
fastlane2's Avatar
Default Exhaut ideas
I have a 97 accord se, I want to put a new muffler on it. I could just put a simple replacement on it. I heard however that there are mufflers or complete systems that sound the same but give more hp. I'm not looking for a loud exhaust. Any suggestions
Old Nov 30, 2008 | 07:42 PM
P_Adams's Avatar
You can graft the Muffler from a '94 - 97 EX w/dual tips.
It flows better than the DX, LX and SE version or
Apexi WS2 (World Sport ll) or equivilent.
I would stay away from "flow-thru" mufflers or any systems based on them if the Police in your area enforce noise ordinances.
P
Old Dec 15, 2008 | 08:09 AM
sghokie's Avatar
Will the stock EX muffler assembly fit in place of the single tip assembly?
Or is the piping different between the 2 parts?
I am refering to the muffler assembly only not the intermediate piping.
Old Dec 15, 2008 | 08:22 AM
propwdialogue's Avatar
My initial instinct is to say that the EX muffler should fit right on with no issues.
heading to www.hondaautomotiveparts.com and looking at the diagrams for the two versions should give you a better idea
Old Dec 15, 2008 | 09:29 AM
sghokie's Avatar
The diagrams of the muffler look identical except for the 2 tips on the ex.
I would hate to order it and not have it fit.
Common sense would dictate that it would be the same.
I have never figured out why the bumpers on all accords have the same exhaust cutout but only the ex has the 2 tip muffler.
Old Dec 15, 2008 | 09:38 AM
P_Adams's Avatar
Honda utilizes the same rear bumper cover for all model Accords for '96 and '97. It will fit
P
Old Dec 18, 2008 | 06:51 PM
sghokie's Avatar
I got the bosal ex muffler and the bosal bolt kit.
The muffler fit great, however the bolt kit was a little less than desirable.
The springs were just as long as the bolt shaft making it difficult to get them in the holes, also the threaded portion was too short to get them in. I was able to get 1 in by using a c clamp to press it in then get the nut on, but after about 20 or 30 mins trying to get the 2nd one in, I gave up and used one of the old rusty ones. The stock bolts were slightly longer with the threaded portion making it much easier to install.
Old Dec 19, 2008 | 03:09 AM
GhostAccord's Avatar
Really if you think about it, it is a no brainer why..... Saves Honda money to make one rear lip vs two or three.
Yes, the complete Bosal exhaust for the EX will bolt right up to the DX, LX chassis. I had no problems with bolts, flanges or gaskets when I replaced my cat back with the Bosal B pipe & Muffler. Sounds really good as well. Never put it on the dyno but I'm sure it freed up a few ponies.
Secret Chimp
Oct 9, 2007 08:58 AM
BEYAAAH
Mar 6, 2007 05:03 PM
lonestar
Sep 18, 2005 05:59 PM
[Caster]
May 5, 2003 07:24 PM
HondaH22A
Feb 7, 2003 04:49 AM
