Oil leak from cv shaft?????
Old Nov 30, 2008 | 12:00 AM
d16man's Avatar
Default Oil leak from cv shaft?????
i was wondering if ur cv shafts arent pushed in far enough would that cause some oil to come out of the trans?
Old Nov 30, 2008 | 09:38 PM
slowcivic2k's Avatar
Yes it will. They will click when they go in. Tug on the joint itself, not the axle, and make sure it doesn't slide back. Otherwise you've distorted the seal on the transaxle, replace it.
Old Dec 1, 2008 | 08:01 AM
94c1v1cex's Avatar
seal is not fun to change
Old Dec 1, 2008 | 09:51 AM
Ahknodd's Avatar
did you change your axles or pull your motor recently? I'm asking to figure out why you'd just start getting an oil leak. Also what transmission are you running? Si, Dx or have you swapped to a b series? I have an Si tranny and I found out the hard way that the seals on the Si are different compared to the Dx. The inner diameter is larger on the Si than the Dx because the inner end of the axle joints have different sealing surfaces. I bought Si seals for my Si tranny and had a huge oil leak because I have Dx axles!! Shitty way to find that out, but just throwing it out there to hopefully save some head aches.
Old Dec 1, 2008 | 09:57 AM
SOHCinWA's Avatar
Change the trans seals and you should be fine.
Old Dec 2, 2008 | 04:43 PM
d16man's Avatar
i just put the motor in the car like not even a week ago and i have had a oil leak since and i kno its not the motor cuz the oil thats in the motor is so clear u cant see it on the dip stick but the oil that i have been leaking is like jet black so im like wtf were is this oil coming from so i looked at the cv shafts and i could see a gap between the trans and the shafts. its not a si trans! me and my friend tryed to get the shaft farther in for about an hour and and it still would not go in any further then it was before so the gap wont go away!!
Old Dec 2, 2008 | 05:09 PM
sgallagher's Avatar
Pull the axle out. You may have damaged the snap ring on the shaft. If the snap ring is damaged it wont go in all the way.
Pull the axle out.
Inspect the snap ring.
Replace if necessary.
Reinstall the axle.
Ensure good fit.
Drain trans fluid. It shouldn't be black.
Refill using MTF.
Surfjunkie44
May 29, 2011 12:53 AM
touintegra1
Sep 28, 2010 12:01 PM
hammergunner
Sep 6, 2008 10:39 PM
dougshatch
Feb 26, 2007 08:49 AM
AgentJam
Sep 11, 2004 05:57 AM
