Del Sol dash Harness help
I'm replacing my current dash harness because it was all chopped and the windows stopped working. I got a new one but there are things that I don't know where they plugin. Does anyone have a diagram of where things go or a pic of there dash not on?
What plugs??
As in how many pins on the plug. You should have:
-clock
-stereo
-cig. lighter
-hazards
-demister
-dimmer (for gauge lights)
-cluster (two of these plugs)
-Possible glove box light
Thats the dash harness... unless you mean the main harness?
If so, most the plugs will go into the underdash fusebox or around it...
A few at the ECU.. Shouldn't be that hard to figure out.
-clock
-stereo
-cig. lighter
-hazards
-demister
What plugs??
-clock
-stereo
-cig. lighter
-hazards
-demister
-clock
-stereo
-cig. lighter
-hazards
-demister
Searched a little harder and come up with it, also every other digram to other cars can be found here.
https://www.spoonhonda.com/SearchResults.asp?Cat=119
Well there will be a few difference in plugs if its an A/T or a M/T.
I'd be guessing its a manual trans loom. You can tell by there being a 2-pin clutch switch which plugs into the clutch pedal... Otherwise there will be about 3/4 plugs in the centre which would goto the auto shifter.
The manual should have all the info you need if you browse it hard enough... I often am looking through the manual for 1+ hour just to find what i need.
This is just off the top of my head but some plugs for things off my EG main harness that i can recall, im sure the delsol harness would have the same plugs.. Looking at it maybe something will jump out at you that you missed..
-ECU plugs (i think 2/3).
-Engine harness plugs
-plugs for the back of the underdash fusebox
-plugs for hooking upto the rear harness
-plugs for hooking upto the harness which runs to the headlights etc on drivers side kick panel
-All the headlight/AC/Horn/Indicator plugs etc.. Im sure you would have worked them out
-2pin plug for hooking upto the loom that goes to the interior light
-clutch pedal/auto plugs
-Earth junction and a earth terminal that goto the drivers kick panel
-IGN switch plugs
-Power window switch (possibly)
-Heater harness plug
Cant think of anything else i may have missed...
Not sure if i've helped or not. I cbf looking at the manual at the moment lol. Mines EG anyway.
-IGN switch plugs
I know the harness is the right one, thats not the problem. Its that their is no spot for anything to go, I remember pulling multiple ones out of the fusebox, on mine tho they lead outside of the car through another harness. Thats why Im looking for a diagram to help explain where everything would go.
-IGN switch plugs
-IGN switch plugs
4 plugs go to the cluster
power window switch is in the door
there's 3 ECU plugs
only thing i can think of that Paul didn't list are the 4 plugs going to above the cluster, for cruise control, aux lights, hazards, and defroster, and possibly the two plugs for the door harnesses (not sure if that's on the dash harness)
What model/year del Sol do you have, and what model/year del Sol is the harness from?
Ok I got the cluster to work good,but the windows still don't work. Only the rear one works like last time, the right one only goes down and the left one dosent move at all. I checked the fuses and they are all good.
Any suggestion's?
Any suggestion's?
Double check all your harnesses and make sure they're all nice and snug.
Did you get all the harnesses plugged into the back of the fuse box figured out?
Perhaps there's a difference in the wiring on the two harnesses, but I doubt that.
The last 2 pictures, yep, that's the problem. The box it leads to is the power window control module I believe.
Those other plugs look like the ones that run to the various relays by the fuse box.
Well found out that the wires are cut out from the harness, and I have another power window module box. Should there be 2? Don't really feel like gettin a new harness since it was a pain to take apart at the junkyard. Maybe someone could tell me what to do with these wires to get my windows working.
Turbo93Eg
Mar 13, 2011 10:11 AM
T_bones
Jun 19, 2007 05:08 PM
