who wants my money?
o.k. guys. i have a b16a1, it smokes a little under boost; even after it was tuned. i am sick of the oil and coolant burning, being unsure of the safety of the motor, and blowing it up then getting all my stuff jacked on the side of the road. so what i want to do is change the head gasket, bolts,and all applicable seals and gaskets for the head, as well as do a little easy upgrading to the bottom end . i have wiseco pistons and shot-peened rods(already in), a new set of crower springs and retainers that will go in, so ill probably do the rod bolt and bearings as well. i have a fuel system(pump,regulator,rail,and injectors) and full oem ignition. to make it easier this is what i had in mind:
1: full top end gasket set(oem or quality after-market)
2: full top end seal set(oem preferably)
3: head and rod bolts
4: rod bearings
5: oil pan gasket
6: piston rings
this is only my second re-build so if there is any thing that i am forgetting, then go ahead and let me know. i would prefer to get as much as i can from one vendor.i know; not always possible, but do what you can. thanks guys.
4: rod bearings
5: oil pan gasket
6: piston rings
lilshady6796
May 23, 2009 11:21 AM
