Car seems to shake idle changes when i use accesories on the car
Old Nov 28, 2008 | 06:40 PM
jdmstockeg6's Avatar
Default Car seems to shake idle changes when i use accesories on the car
i have 1993 civic w/ b16 swap. power options i have are. power windows, stereo, foglights, rear fog light, bumper pole, side markers and regular front headlights and tail lights. when i start the car its fine. but when i start using stereo, power windows all the rest the car seems to shake and the whole car vibrates harder than usual esp when im stopped at a stop light or something. what could be the problem? battery? alternator? loose connections? better grounds? small wires? not sure what it could be, any suggestions would help thanks!
Old Nov 28, 2008 | 07:17 PM
98greensi's Avatar
how long has it been since you've done a tune up? i'd start there then get the charging system, checked a shop has a tool that will diagonse the system and give you the actual amps of what the alternator puts out etc.
Old Dec 1, 2008 | 06:10 AM
you know what tool its called?
Old Dec 1, 2008 | 06:37 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The idle may be too low. It needs to be adjusted from time to time.
Here:
1.) Turn on car and let it warm up. Turn off all accessories.
2.) Unplug IAC. The idle will drop.
3.) Adjust idle screw on throttle body. It's a large flat head screw on the front of the throttle body.
4.) Adjust idle to manufacturer's spec. It should be on the inside of your hood. If you don't have the original hood, IIRC, it's around 600-800RPM for manual motors.
5.) Replug in IAC.
6.) Turn car off.
7.) Turn car on. Check idle with accesories. Rev it a couple of times and see if the idle stays.
8.) If idle is good, you're done. If not, then repeat steps 2-7.
Old Dec 1, 2008 | 06:38 AM
B serious's Avatar
You can also clean the throttle body and IAC with sensor safe throttle body cleaner. Don't use brake cleaner.
Old Dec 1, 2008 | 08:24 AM
Evs-One's Avatar
Solbros Owns Me
750 +/- 50 rpm is idle spec for the car.
The idle should be just below 500 with the IAC valve unplugged and engine warm, not at spec.
plotomatic
Sep 24, 2016 08:29 AM
djrockytharp
May 28, 2008 10:41 AM
boostcrx89
Jan 13, 2008 07:04 PM
91-lsvtecsi
Mar 8, 2007 08:14 AM
simplsi
Nov 7, 2006 08:28 AM
