HELP! Irratic, super high idle
Old Nov 28, 2008 | 11:00 AM
CivicKid1181991's Avatar
Default HELP! Irratic, super high idle
Okay well I know on D15B1's theres a restrictor plate, so I went and took it off, put everything back together, and my car idles at 2000 and fluxuates up to 2500. Well I went and put the restrictor plate back in and it still does it, the only thing i did was the gasket between the plate and the intake manifold, I took it off (Ripped) and I used RTV silicone. I know all my things are hooked up. I undid the gas pedal, so I could move the throttle body easier, anyway, anyone know what my problem is??? Cuase I got the coolant line hooked back up, I got the restrictor plate back in allt he vaccume lines are in place, I jsut IDK what the problem is... Can someone help me?
Old Nov 28, 2008 | 11:15 AM
digitally_remastered's Avatar
to me sounds like its a vacuum leak. id check the actual hoses for holes/rips/something. then a diagram.
Old Nov 28, 2008 | 12:05 PM
Well I was checking the diagram on the hood and all myhoses are good, and my car dies back down to idle id I undo the vacum line from the throtle body that runs to the electrical units ont he fire wall.. So does this help any, and how can I check for vaccum leaks. Also for some reason I got it to start idling lower, like in the 1500-2000 range,
Old Nov 28, 2008 | 01:36 PM
Sorry fro double posting, but my mom (Yeah moms the mechanic of the house) Siad that the hoses, where they are old, that hwne I pulled them off i may have stretched them and there leaking around, so I am going ot replace the lines with all new, think it will work?
Hondapreludeg
Honda Civic (2001 - 2005)
14
Feb 18, 2013 02:23 PM
Excusetoboost
Sep 1, 2011 07:40 PM
ILoveJDM.
Nov 17, 2005 01:42 PM
DOMKID
Jun 20, 2003 10:36 PM
NOSed_b18b
Nov 21, 2001 06:17 AM
