wtf is code 14?
ics malfunction? I dont understand. I have a 97 civic dx with a d16y7. The motor was from an automatic and i have a manual.
My idle is at 2000rpms and then sounds like i have cams because it goes from 2000 to 1900- 2000-1900-2000-1900 real quick.
help me anybody
help me anybody
idle air control valve is faulty. replace it. its on the back of the intake manifold. i know you can clean them out with brake cleaner but i was told it doesnt work to great on hondas/acuras. (Also it being just dirty wouldnt throw a code.) most likey an open in the solenoid.
-D16Y7 -> IACV on throttle body, both automatic and manual
-D16Y8 -> IACV on throttle body on automatic versions, IACV on intake manifold on manual versions.
as stated before, if its not throwing a code and is idling funny, cleaning will work.
if it is throwing a code then usually it needs the whole IACV cause the solenoid is fubar.
also, if you clean one too many times the valve will end up dieing on you.
javifunksEK
10
Feb 28, 2011 08:10 PM
calvin924597
Jan 29, 2010 06:24 AM
