swap has shaking problems
Old Nov 27, 2008 | 11:29 AM
gsrEGcoupe's Avatar
New User
Default swap has shaking problems
i swapped b series into my EG coupe, only problem is the car shakes in 3rd and 4th gear, shakes only a little bit in low rpms and shakes more in higher rpms. anyone have any ideas on what the problem might be?
Old Nov 27, 2008 | 11:30 AM
lcsej1's Avatar
stumbles or shakes?
Old Nov 27, 2008 | 12:25 PM
gsrEGcoupe's Avatar
New User
shakes
Old Nov 27, 2008 | 12:55 PM
slimjimming6688's Avatar
MABY ITS A TRANNY PROBLEM..
Old Nov 27, 2008 | 01:09 PM
Syndacate's Avatar
That was quite honestly the worst attempt at help I've ever seen.
Can you elaborate on what you mean by "shakes" - Does it shake, as in the car isn't getting enough fuel (like the engine's spitting), or does it shake like a wheel is out of balance, is it shaking like you threw an axle balancer? (even though civics don't have axle balancers)
How exactly is it shaking? The more you describe, the better help you can get.
Old Nov 30, 2008 | 07:21 AM
gsrEGcoupe's Avatar
New User
its not just the motor sputtering, its different than that its more like the whole car shakes like one of the axles is loose but they have both been checked and replaced, the only gear it shakes in is 3rd. like as you shift in and step on the gas it starts to shake and if you start to get on it, it shakes more until about 5800 rpms then it stops and goes smooth.
Old Nov 30, 2008 | 09:41 AM
how fast are you going when you shift in 3rd?
Old Nov 30, 2008 | 10:30 AM
ek_h22's Avatar
Make shure all youre motor and trans mounts, even loctite them, chek all the tranny bolts to the motor, the best way to get these bolst tight is a 3/8 impact. one more thing what condition is youre clutch in?
Old Nov 30, 2008 | 10:34 AM
2000siturboR's Avatar
alignment issue perhaps
Old Nov 30, 2008 | 01:36 PM
97_coupe's Avatar
Are you sure that its only until a certain RPM in 3rd gear or could it just be the speed at which your going in 3rd? Can you go the same speed in a different gear and not have any "shaking"? If not, check the condition of your tires, wheel bearings, alignment, ect.
Old Dec 1, 2008 | 02:21 PM
gsrEGcoupe's Avatar
New User
already tightened all the mounts and tranny bolts with a half inch impact.
and yes i can go the same speed in all other gears with no problem, its only third that shakes.
Old Dec 14, 2008 | 04:47 PM
caeavesRSX-S's Avatar
First you said it shakes in low and high rpms, then you said it smooths out at 5800. Which is it? There is more load on the engine at higher gears and low RPM so maybe it is a tune up issue. Did you change the plugs, wires, distributor cap and rotor? Fuel filter new? Sometimes its a simple tire balance issue that only happens at certain speeds independent of gear issue. Try matching the same speed in 5th and see if the vibration occurs.
Old Dec 14, 2008 | 07:02 PM
93egSLEEPER's Avatar
go back through and check all your mounts. i had the same problem because i lft the top bolt on my rear y mount loose. tightened it and it was fixed.
Old Dec 14, 2008 | 07:12 PM
builthatch's Avatar
MiG-21 superfan
is the car lowered?
if so, can it be raised (coilovers)?
you might want to also search 'vibration' in the hybrid forum. remember, the hybrid forum is specifically for engine swaps and related items.
JunIntegra
Honda S2000
19
Oct 20, 2008 10:56 AM
dc2[HI]
Aug 7, 2008 11:03 AM
MagnusNirell
Jul 8, 2005 11:09 AM
rafforama
May 6, 2003 11:01 PM
