gsr motor in 95 del sol HELP!!
hey people, first of all i wanna start saying i just got obd2 97 gsr motor. I wanna do a swap in my 95 del sol s(pretty soon). i guess i'm just confused about the engine wires harness and such.
I need a straight up answer please someone. i been reserching, the more i reserch the more i get confuse. here are the things i'm confues about. any tips or hints will be apprecitaed.
1. what year of ecu should i use?
2. since it didnt come with distributor. should i use obd1 or obd2?
3. how about engine harness?
I need a straight up answer please someone. i been reserching, the more i reserch the more i get confuse. here are the things i'm confues about. any tips or hints will be apprecitaed.1. what year of ecu should i use?
there is a walk through for this swap.
the obd2 motor will bolt and wire up
you dont need to change the distributor
use the engine harness.
use a obd1 gsr ecu
you will need to swap 1 or 2 wires and wire vtec(if needed)/knock sensor, also make sure you get del sol dohc shift linkage.
i've done this exact swap, and have had it running in my present car for 2 years with no issues.
use a obd1 gsr ecu
you should choose your distrubter by the engine harness you have. and if you get a chipped p28 you dont have to worry about the knock sensor or the secondary butterflies. as far as wiring is concerned try to get the two wiring diagrams, one for the engine and the other for the chassis. just compare and switch around as need be.
I have a 96 GSR on a 93 Del Sol si. Chip your current ecu to be able to disable things and make life easier. Everything on your motor including the harness should stay obd2. Also like stated, get the Del Sol Vtec shift linkage. Pretty easy swap that can be done by the first timer. All plug and play!
This will help also:
http://www.ff-squad.com/technet/hybrid.92-95.obd2.htm
ur so awsome. great site. now i can move on with ease
use a obd1 gsr ecu
use a obd1 gsr ecu
as everyone is saying using obd2 motor combine with obd1 ecu. will that work perfectly? nothing will interfer or anything right? this my first time so I wouldnt know all that much.
Get your ecu "chipped" and you will not have any problems. Your going to want to disable IAB's, knock, and 02 sensors. Or you can get a p72 ecu and just run that. If you leave you stock ecu in there it will not run right.
Just do this, send your ecu in to Phearable.net and have him chip it. When you get it back you will be golden on that end of your swap.
i dont have a ecu at this point. what ecu am i going to get for chipping?
JDM Jeff 95civ
Nov 9, 2010 01:54 PM
avianman
10
Mar 21, 2009 04:29 PM
