Accord emergency..........won't start.....Dizzzy?
Old Aug 1, 2002 | 12:33 PM
Charlie Moua's Avatar
Default Accord emergency..........won't start.....Dizzzy?
damn i can't get my accord to start. This is the first time. It's an auto 93ex.
I have the MSD 6al unit with blaster 2 coil and distributor cap. I heard some where that MSD caps mess up your dizzt after a while(had MSD it for 1.5 years)
-The motor cranks but won't turn over.
-I just changed plugs and still have magnacore wires.
-battery is good
-all fuilds checked and ok....
WHAT COULD IT BE??????????
Old Aug 1, 2002 | 12:36 PM
Martaigne's Avatar
Default Re: Accord emergency..........won't start.....Dizzzy? (Charlie)
Got fuel?
Old Aug 1, 2002 | 12:40 PM
Default Re: Accord emergency..........won't start.....Dizzzy? (martaigne)
yup got fuel.
Old Aug 1, 2002 | 12:42 PM
ArchAngel Sabastian's Avatar
New User
got fuel hmmm
not clogged or anythin?
[Modified by Sabastian, 3:44 PM 8/1/2002]
Old Aug 1, 2002 | 12:47 PM
H23 Power's Avatar
Default Re: Accord emergency..........won't start.....Dizzzy? (Sabastian)
ur missing spark somehow...coil bad? cap could be bad...or just a bad connection on your msd stuff
Old Aug 1, 2002 | 12:49 PM
Raisn_Hell's Avatar
Default Re: Accord emergency..........won't start.....Dizzzy? (01GSR)
My bet is on the coil, but it could be the cap
Old Aug 1, 2002 | 02:59 PM
CardDealer's Avatar
Banned
Default Re: Accord emergency..........won't start.....Dizzzy? (Raisn_Hell)
Modified by CardDealer at 4:25 PM 11/17/2006
Old Aug 1, 2002 | 03:43 PM
Chiovnidca's Avatar
yup got fuel.
Got spark?
Old Aug 1, 2002 | 03:48 PM
CardDealer's Avatar
Banned
Default Re: Accord emergency..........won't start.....Dizzzy? (Chiovnidca)
Modified by CardDealer at 4:24 PM 11/17/2006
Old Aug 1, 2002 | 07:34 PM
Accord94DX's Avatar
Default Re: Accord emergency..........won't start.....Dizzzy? (schlit)
main relay.
Old Aug 2, 2002 | 04:49 AM
Default Re: Accord emergency..........won't start.....Dizzzy? (Accord94DX)
well after about 1 hour i went back out there and tried it one more time. it started up easly. So i just took it to Honda for them to take a look at it. This is the first time in 3 years that i have had any problems with starting. (sorta makes me appricate having a reliable car) Well i have my civic in the garage... i'll just drive that for today. I'll let you know what Honda says.
Old Aug 2, 2002 | 04:50 AM
Stew Pidasso's Avatar
Check the output of the coil first.I just had my blaster 2 go bad on me and the car wouldn't start.If you have fuel and spark the go for the main relay.
Old Aug 2, 2002 | 06:09 AM
notoriousB's Avatar
Default Re: Accord emergency..........won't start.....Dizzzy? (Nitz5785)
Check the terminals inside your distributor cap and the contact on the rotor!! This week my 6th gen wouldn't start for a while, then it kicked right over an hour later. I thought it was my Nology ignition coil amplifier, but it turned out that the terminals on the disti cap were all corroded looking and the contact on the rotor was black not gold... I hit all the contacts off with sandpaper and it fixed the problem, but I just got a new cap & rotor...
Old Aug 2, 2002 | 09:43 AM
so how long or Miles have you had the coil blaster for? how do you know it needs to be replace?
Old Aug 2, 2002 | 11:38 AM
notoriousB's Avatar
I don't have the blaster coil, I have the Nology power core coil booster... anyway I've had that on the car for about 7 months, but I think my distributor cap is stock (~48k miles). Check the four terminals inside the distributor cap. They should look clean and the surfaces should be smooth. If they look bumpy or corroded, there's your problem. Sand them down for a temporary fix. Also check the contact on the rotor (on the end, like a strip of metal), it should be gold or silver. If it is black, that's a problem... again sandpaper will help at least temporarily...
Old Aug 2, 2002 | 11:47 AM
I actually didn't have mine for very long.Maybe 6000 miles or so (probably defective from the factory)
I took the plug off of the distributor (coming from the coil) and held the metal part of the connector close to ground and had my girlfriend crank it over..no spark.I replaced the coil and it worked fine.
Just don't get too close to the metal part or you will get a nice ZAP. I used a pair of insulated needle nose pliers to hols the wire too.
Old Aug 2, 2002 | 01:13 PM
well just got a call from honda it's gonna cost me $235 for parts and labor for a new main relay switch....(ouchhh)
Can you tell me what a main relay switch is? what it does? where it is in the car?
Old Aug 2, 2002 | 02:13 PM
Go here and you will save a bunch of dough http://www.hondaautomotiveparts.com/
They ship out quick too...you usually get it in a couple days.
Old Aug 2, 2002 | 07:53 PM
Can you tell me what a main relay switch is? what it does? where it is in the car?[/QUOTE]
please answer this question
Old Aug 2, 2002 | 08:26 PM
Accord94DX's Avatar
What year accord? It is an electrical relay for your fuel pump and pgm-fi system. At honda, we see about 30-40 of these come in a week during the summer. VERY common problem.
Old Aug 2, 2002 | 10:46 PM
civic7gen's Avatar
ITS the friggen MAIN RELAY my friend.. i need to change mine very soon as well. but im poor at the moment..
Old Aug 3, 2002 | 10:13 AM
Slammed2K1's Avatar
New User
Default Re: Accord emergency..........won't start.....Dizzzy? (Accord Maniac)
I have the same problem, intermittent fuel, is it just the relay that's under the steering column area, above the fuse box? Or something else, somewhere else? '90 LX
-Chris-
[Modified by Slammed2K1, 7:17 PM 8/3/2002]
Old Aug 3, 2002 | 10:22 AM
Razor's Avatar
yeah thats what happens if your main relay has gone bad, especially if the car is warm or has been sitting in the hot sun. since it turned on immediately after a couple of hours, i really think its your main relay. happens to a lot of 4th gens for some reason.
good luck
Old Aug 4, 2002 | 02:47 PM
Default Re: Accord emergency..........won't start.....Dizzzy? (Razor)
damn ya'll smart...... yeap it was the main relay and your also right about sitting in the hot sun.
Old Aug 4, 2002 | 03:09 PM
pstutz's Avatar
My 90 LX has the same problem, refusing to start when hot in the summer afte you leave it sit for a little while. When it cools down and I heat up, it starts fine. I would like to replace the main relay, and assume it is item 28 from the link above on a KA5MT engine. Please confirm or deny, so I can replace it and live on blissfully................. Phil
