Endless coolent leak
Over the past month or two my car has been randomly overheating. When it first started I found a leak in one of my hose's so I had a new one put in. I thought that would have solved the problem but then a week later it overheated again. Now the problem is its overheating every 5 to 6 days (refilling with about half a bottle of coolant everytime it overheats) and I cant find a leak anywhere. Im letting my car cool down right now, then going to go let it warm up one more time to see if I can find a leak.
Maybe there's something im overlooking?
I even tried that stop leak from autozone untill I could buy a new radiator but that stuff is just about worthless.
check for air in the system. When it first started leaking you lost fluid and it was replaced with air, then you refilled on top of that air. Just my guess.
Also I noticed you said....
obviously you need a new radiator
I bought a new one yesterday, should be putting it on tomorrow.
Whenever I put the new thermostat in im going to flush the system as well.
That was my assumption from the begining, that the radiator was toast but id rather know for sure instead of buying a radiator and it overheating again the next day.
the lost coolant after overheating doesn't necessarily indicate a leak. what's probably happening is the safety release on the radiator cap is opening the let pressure out when you overheat.
also, running low on coolant isn't the only cause for overheating. just to be clear.
on with it... for everything to work correctly and stay cool the radiator fan must come on when the engine gets to normal op. temp. the thermostate needs to open as well. you can feel the heat of the coolant in the hoses when the thermo. opens. you can jump the two pin harness to the coolant temp sensor on the thermostat housing to check the fan quickly. (i'll say it to be thurough) you need to be full of coolant. and the water pump needs to be moving coolant.
i wouldn't jump to the conclusion of a bad head gasket... not without other headgasket symptoms.
i would check the fan first, if that's good then make sure your radiator cap looks good and seals properly. and unless you have over 100k mi. on a cheapo-cheap waterpump, leave that till last. Pressure testing is the way to check for leaks, look around especially underneath with a light for any dampness. then trace it back to the source. the problem should turn up by that point. good luck!!
A warning: overheating is super bad for aluminum motors. you want to get if fixed quick and right so you can avoid more potential damage.
spyderracing
12
Sep 23, 2004 12:15 AM
