Oil on spark plug #4
Old Nov 26, 2008 | 03:30 PM
t0kyoStatus's Avatar
Icon2 Oil on spark plug #4
I was changing out the plugs and seen a little oil on spark plug hole number 4. 4-3-2-1 right? Do I need a new valve cover? This motor was just bought from H motors. Site search hasnt been working.
-Thanks
Old Nov 26, 2008 | 03:33 PM
b16_sol_707's Avatar
check the spark plug tube seals, they are little 0 shaped seals on the bottom of the valve cover.
Old Nov 26, 2008 | 03:36 PM
EmminoDaGreat's Avatar
thats not a valve stem seal on the bottom of the valve cover. A valve stem seal is exactly where it sounds like it is, at the valve stem. Spark plug tube seals usually will fill the tube up and cause a misfire
Old Nov 26, 2008 | 04:23 PM
I don't know what I was thinking when I typed that...Was still thinking about another thread I read right before this one. sorry about the confusion.
Spark plug tube seal.
Old Nov 26, 2008 | 04:37 PM
abusedhusband's Avatar
change your valve cover gasket and spark plug grommets in the valve cover
Old Nov 26, 2008 | 05:27 PM
b17rider's Avatar
X2
Old Nov 26, 2008 | 06:06 PM
95dxsir2's Avatar
is the oil on the spark plug electrode end or on the porsline(white end)?
if it's the white end...do the above
Old Nov 26, 2008 | 07:05 PM
enycesam's Avatar
Yehp, the spark plug tube seals.
KevinVX
27
Nov 9, 2014 03:50 AM
Jokergp
Sep 3, 2008 10:54 AM
Dj Skidz7
Apr 29, 2008 11:16 AM
turboteg90
Oct 9, 2007 04:53 PM
Red_Si
Oct 26, 2006 10:48 AM
