HELP!! Car bog Badly after 6k.
Old Nov 26, 2008 | 11:07 AM
RedValve's Avatar
Default HELP!! Car bog Badly after 6k.
For some reason my car bog really bad after 6000rpm, some of my buddy said it might be the injectors and some said to check the dizzy out.Also this is maybe why my Vtec not kicking in, so basically right now im running a ls instead of a GSr.
My question is has anyone ever had this problem happend to them? what cause it and how did you fix it if you did.
feel free to chime in..
thanks... =]
Old Nov 26, 2008 | 11:25 AM
neardon's Avatar
I'm a Jackass
Is that CEL on? Is the timing right? Do you have enough oil? Have you checked your fuel filter, distributor cap and rotor? Is your car completly stock?
Old Nov 26, 2008 | 05:20 PM
RedValve's Avatar
not cel on, timing check,just did oil change,havent change fuel filter yet, like i said before some people said to check out the dizzy, and yes it completely stock beside for the intake.
and vtec still not working, open it up and check gasket and everything and still not working.I think it might be the wiring, but dont know what it look like when it done right so im not going to mess with it.
ahayden
May 20, 2015 04:39 AM
GSR coupe
Feb 27, 2010 12:11 PM
capm.stabahoe
Dec 27, 2008 06:17 PM
young-richie
Aug 23, 2007 06:57 PM
SlowSOHC-T
Nov 25, 2005 08:56 AM
