GETTING NO FUEL????
im getting no fuel to the car what could be the problem. the main relay is good you think is its the fuel pump? what are the main problem for not getting fuel???
do you hear the fuel pump prime when you turn the ignition to the 'on' position? If not, you probably have an electrical issue somewhere. Could be a fuse or relay.
And how do you know the main relay is good? Did you find the resistances and test it?
Agent Daimon
Feb 9, 2003 01:06 PM
