No power to the fuel pump. please help
Well for the last week or so i been working on this. my fuel pump will not turn on. I hard wired the pump and it does work . I installed a new main relay part number 0132 . I checked all of my fuses still not working. Anyone give me any ideas? is there another relay that it runs off of? if i cant get it to work today i am just going to hardwire the pump with a on off switch
You probably already know this so don't take it as an offense. The fuel pump will only be energized by the main relay for the time the CEL is lit when the ignition key is first turned to the 'run' position. Once the ECU senses the engine is turning, the main relay is energized again. If you have no power to the pump at all when the key is first turned to 'run' ... Does the main relay click on and then off when the CEL goes out? If so, the wires to the pump should be checked. If not, you'll have to backtrack the wireing through the fuse panel.
hondaluver12
Jan 30, 2012 02:37 PM
insomniac791
Jan 22, 2004 04:23 PM
