Honda S2000 Honda S2000
AP2 base timing
Old Nov 26, 2008 | 05:37 AM
R@mon's Avatar
Default AP2 base timing
What is the factory base timing for an F22c?
Old Nov 26, 2008 | 06:20 AM
DO_ITR_YoungD_19's Avatar
I hope someone know because i cant find it anywhere in the internet.
Old Nov 26, 2008 | 11:48 AM
SuzukaBlueAP2's Avatar
maybe I don't fully understand what you mean by 'base timing'. Are you trying to figure out what the stock ignition timing should be set at?
Old Nov 26, 2008 | 11:55 AM
honeybadger's Avatar
Just hit up your local tuning shop they should be able to tell you anything that you need to know about the timing?
Old Dec 1, 2008 | 07:36 PM
keeblertime's Avatar
5±2 °BTDC [RED mark (B)] at idle in Neutral
that is from a reliable source
Old Dec 7, 2008 | 08:56 AM
S2KFTW's Avatar
that's what's the shop manual says for the timing at idle. the white mark on the crank is TDC, the red mark is 5 degrees advance, the unpainted grooves to the left and right of the red mark are + - 2 degrees timing.
if you're looking for a full timing map if you download AEM's EMS software there's some base maps, Hondata's software also comes with some base maps. they're different at part throttle but fairly close at WOT.
prodjay10
May 6, 2016 10:43 AM
handa
Apr 11, 2005 10:36 AM
Weq
Nov 21, 2004 08:42 AM
civictypenos
Oct 9, 2003 04:07 AM
joestud
Jul 9, 2002 11:49 PM
