Oil Pump question
When building a new motor or tearing a motor down after a season do you replace the oil pump or just open it up and check it? Everytime I put a motor together I am buying a new oil pump for that piece of mind. But as I was going through my attic today looking for parts I have about 11 oil pumps up there. Some were used for less then 500 miles.
Do you recommend a new one or just taking one apart and checking it?
Thoughts?
Thoughts?
the three engines i have built, (for myself) all 3 got a new oil pump, strictly because i have beat the hell out of them, and dont want anything i cant see during an inspection coming back to bite me in the ***.
I guess we got lucky. The single cam used the OEM pump with 216,000 miles on it, just shimmed for high pressure.
Why do you think you need to keep buying oil pumps, if it ain't broke, don't fix it. I'll bet you buy new water pumps too.
Because with my great luck with motors the last thing I need to do is have one fail b/c the oil pump took a ****. And yes I buy a new water pump, timing belt, tensioner, gaskets the whole nine. When I put a new motor together.
When I drop valves depending how late it is I might reuse the autozone headgasket.
Hahahaha, brand new oil pumps, tensioners, belts and an autozone headgasket. You are something else man.
I'm running the oil pump that came with my engine, god knows how many miles is on it. Water pump is new, but they're super cheap.
I use a new pump with every new motor. It's probably more psychological than anything, but my last two motors did have some pretty bad damage and I wasn't sure if any fragments got into the pump. I would rather err on the safe side.
Don't knock the autozone headgasket lasted almost 2 years, with numerous dyno pulls, a ton of passes down the track and not a single issue. My motors didn't even last that long, and we reused it once or twice I forget.
they still break no matter what name ...but people still say their isnt a prob with them lol...idk, but i learned my lesson years ago with them and went peterson external wet sump best thing i ever did,and while i was at it i went with meitzer external water pump also kill 2 birds with 1 stone .lol.
Lei Siew Long
Apr 17, 2002 08:54 PM
