94 Civic D16z6 spark plug tube seal question with PIC
Hello,
I am in the process of replacing the valve cover gasket, spark plug seals and I have a couple of questions.
1. I am having a difficult time removing the old spark plug seals. What Can I use to remove them without damaging my valve cover? I was thinking vise grips to pull them out, but once again, they are really in there.
2. The manual states states to, "Apply oil to spark plug tube seal when installing". Can some one explicitly in detail tell me exactly WHERE it is asking to apply the oil? (i.e. around the entire seal before installing, after its installed around the outside,keeping the inside clean).
I am very slow so please give details of the exact process. Thanks folks!
use a pretty thick screwdriver and pop them out by sliding it under one part of the seal and pry each one till they pop out... or you can use a small punch tap on one side and it should rock loose... and second the reason they want you to apply a thin coat of oil on both the inside and outside of the tube seals is actually for two reasons one is to ease installation into the valve cover AND to make sure you don't cut the seal sliding over the plug tubes...
ok cool. do you think i might accidently bend in the valve cover lip with the screwdriver by using the pry method? Lastly, can i just use standard 5w30 to coat the seals?
The old seals can be bitch to remove they get very hard with age. Just do as wrenchez81 discribed and take your time. Also when installig the new seals it doesn't hurt to add a little oil to the seal when installing them
you wont bend it because your prying under the seal. so one end is nder the seal and your pry point will be the top part of the seal get it... so what your doing is actually rocking the seal to where itll pop free... you may not be a doctor but ur gonna need patience.. and yes 5w-3o will be fine...
^^^ i wouldnt try that if your a noob!!!! just askin to f*#$k sumthin up!!! and if you use a torch BE CAREFUL!! don't forget ur workin on aluminum which can distort easily... but hey its your valve cover... if you mess it up i have two u can buy!!! aaaaaand if the seals are hard and brittle you are more than likely not going to get the proper grip neccesary to do so.... hope it works out for ya bro!!!
are they really that hard to get out!? i've removed and replaced these things countless times and every time thus far they've basically just fallen out of the valve cover, or remained attached to the spark plug tube itself. no prying necessary.
philkehn
May 23, 2006 09:06 AM
