Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Is this worth getting?
Old Nov 24, 2008 | 01:30 PM
djdownfawl's Avatar
Icon2 Is this worth getting?
Front Lower X-Brace
http://neuspeed.com/products/product...mport&p_id=814
thank you
Old Nov 24, 2008 | 01:44 PM
tragiclude875's Avatar
yeah it is betta handling.. ull notice the diff soon as u install it
Old Nov 24, 2008 | 02:07 PM
djdownfawl's Avatar
Default and now...
And now i find out through research.. there is a double X brace that D3 offers. Better than neuspeed?
whats the best one to go with? worth it? not worth it? Improves anything?
Old Nov 24, 2008 | 02:32 PM
Whatislove's Avatar
I asked this question here before about this part and was told that its worthless
Old Nov 24, 2008 | 02:42 PM
unevolved's Avatar
It serves the exact same purpose as the OEM subframe. I've heard it's very much not worth it. That part was originally designed for cars that don't have subframes in the same sense, then modified for the EM2. It's an answer to a question no one was asking.
Old Nov 24, 2008 | 02:50 PM
Whatislove's Avatar
the subframe is still a bolt on itself and has engine mounts on it. I think technically adding that might provide some stiffness.
but poly engine mounts would be a better investment
Old Nov 24, 2008 | 03:45 PM
D17alltheway's Avatar
wouldnt you be scraping everywhere with that sled under your car?.. i already scrape
Old Nov 24, 2008 | 05:30 PM
unevolved's Avatar
Here's the subframe for reference:
It may provide some stiffness, but it's stiffening a part that's there to stiffen in the first place. It will lower your ground clearance and do next to no good, in all probability.
So no, it's not worth it.
Old Nov 24, 2008 | 05:45 PM
metalviper's Avatar
that is apples and oranges. the es engine mounts help with engine movement dampening. the braces help reduce chassis flex and weight transfer under hard cornering. the d3 brace is supposed to pretty good if you research it on ephatch and crsx. it ties a few weak points together. but like the strut bars do for our cars, the neuspeed is more of a "feel" improvement than actuall performance gain with a unibody car.
Old Nov 24, 2008 | 06:15 PM
katzenjammer84's Avatar
You're going to be connecting solid mount points to solid mount points, which gives your car a structural integrity improvement level of 0%. You'll also be dragging it across speed bumps and potholes.
Make your own conclusions.
Old Nov 24, 2008 | 07:15 PM
unevolved's Avatar
Isn't that what front strut tower braces do?
Old Nov 24, 2008 | 07:46 PM
The firewall relative to the suspension mounting points are in no way an ideal design for ultimate structural rigidity. Considering the amount of chassis flex and sway most front engine, FWD cars display, it's a worthy investment to brace that point of the chassis.
What kind of flex will be generated in the X-frame case? At the very least, on a "properly" setup car, it's a redundant piece of metal work.
There are plenty of redundant pieces on the market. The inner fender brace is another one.
Old Nov 24, 2008 | 07:55 PM
ejLday's Avatar
i don't know if it is really going to make a noticeable difference
Old Nov 24, 2008 | 08:25 PM
djdownfawl's Avatar
Aren't you on Radar Detector also?
Old Nov 25, 2008 | 06:45 AM
Whatislove's Avatar
ok, so is crap
get a tower brace instead or whatever
Old Nov 25, 2008 | 04:10 PM
No sir.
stpcivicguy
84
Aug 21, 2012 10:00 AM
Sw33t_SI
19
Aug 10, 2011 10:31 PM
senmex
Jun 23, 2008 07:33 PM
SIDEXIT
Sep 9, 2007 05:09 PM
EJ8VTEC
Mar 8, 2006 12:59 PM
