automatic tranny problem..dont know waht to do ?
Old Nov 24, 2008 | 10:14 AM
crazyFaizy's Avatar
Default automatic tranny problem..dont know waht to do ?
i have a honda accord 1997 ...4speed auto.
and it starts and runs normaly...but when i start to apply more gas pedal ( more power) to the engine a growling sounds appears and when i ease my foot abit it goes away,,,(reduce engine load) my bet is the tranny is running out life,,maybe,,ooh and when it shifts it sound like somone gave it a punch in its belly,,,(the whole car shakes..) im tired of this,,if anyone can help me with this ill be gratful
Old Nov 24, 2008 | 10:44 AM
bseriescrxsi's Avatar
tranny issue....possible timing belt
Old Nov 24, 2008 | 10:55 AM
P_Adams's Avatar
I would check the engine / transmission mounts. It sounds like one has collapsed and allows the powertrain to bang / rub against the subframe whenever under a load or it shifts. Pay particular attention to the rear mount. It is vacuum assisted and is prone to "buying the farm".
I would also check the exhaust system for a component too close to the chassis. As the engine shifts / jumps this could be hitting as well.
P
Old Nov 24, 2008 | 11:02 AM
crazyFaizy's Avatar
right,,but how can i tell if the mounts are worn out ? (physical inpection )
Old Nov 24, 2008 | 11:10 AM
P_Adams's Avatar
Visible inspection is one way. Look for torn insulators and any misalignment between any of the mount components.
You can also inspect them by trying to induce movement with a pry bar or like impliment. Ther should be NO movement
P
Old Nov 24, 2008 | 11:23 AM
crazyFaizy's Avatar
thanks alot P_Adams....ill see if this gives any results,,,
Old Nov 24, 2008 | 03:56 PM
YeuEmMaiMai's Avatar
These transmissions are known for shifting hard since honda did not retard timing during the shift. also as they get older they shift even harder. as long as it is not SLAMMING into gear as though it was slipping, you're good.
To reduce the harshness of the shift, flush the trans (drain and fill 3x with a drive inbetween each time) and on the final fill add a can of lubeguard for imports (red cap)
Old Nov 24, 2008 | 04:18 PM
Shag Wagon's Avatar
Never never NEVER flush an old dying transmission. It will die right after you do it. I have seen it three times and has even happened to me. For some reason I think the old **** inside the tranny does something to help it keep going. Best thing you can do is buy 3 quarts of HONDA tranny fluid and maybe a little bit of Lucas tranny fix (yes I have tried it and it does help a little) and just change it every 15k. I have been riding on a bad tranny for 2 years and I havent had one problem except for occasional slipping and overdrive comes and goes.
Old Nov 24, 2008 | 04:34 PM
no, it won't......just do the HONDA recommended service and add the can of lubeguard for imports and you'll notice an IMMEDIATE change for the better. Been there done that on MULTIPLE CARS with well over 100K on the trans
Old Nov 24, 2008 | 04:42 PM
P_Adams's Avatar
Still, check the mounts.....
P
Old Nov 24, 2008 | 08:58 PM
most shops wont even touch honda trannys because their prone to fail after a flush...from what ive heard it screws up the planetaries inside....dont know...was never that eager to spend 350 on a new tranny from tryin to do a flush on it
Old Nov 24, 2008 | 09:53 PM
lawl people talking crap. the reason most shops don't mess with honda transmissions is because they usually do not stock honda atf fluid....... they usually stock type F, Mercon X or Dextron X............
btw honda transmissions are not known for leaking unless there is something wrong with them internally causing the leaks around the axle seals or solenoid seals......
and please provide the statistical data to show us where honda transmissions are prone to failure after the honda recommended way of 3x drain and fill.
I can provide the link to where I got my information
http://auto.howstuffworks.com/honda-accord5.htm
Old Nov 28, 2008 | 02:52 AM
crazyFaizy's Avatar
ive checked the mounts....they are torn badly,,,also had my friend rev the engine at Neutraliz gear postion,,the thing shakes like crazy like it did not do before,,
its obvously not normal,,,the mounts have go,,NOW,,
you were right adam_p...i can eeeasily peel the rubber with two fingers like taking a peice of bread,,,
as for the lucas lubguard,,i was trying to locat that in the uae (in the state of ajman in particular) and its so damen hard to find it,,,
how ever...
i found this and its near were i live...
http://www.lubex50me.com/products/li...e/txldmsds.pdf
its called lubex 50 ,,,and it happens to be transmission lube additive,,,
not sure if it is suitable for my application,,,
by the way thanks for all who have tried to help me,,realy apprecait it...
Last edited by crazyFaizy; Nov 28, 2008 at 02:54 AM. Reason: missed to mention an infermation
Old Nov 28, 2008 | 03:29 AM
doubleRdazz's Avatar
after you change the mounts that are broken you can also add the lucas transmission additive
that stuff works really well and its easier to find
Old Nov 28, 2008 | 09:38 AM
P_Adams's Avatar
Glad I was able to help. My wife's '88 (now a 'spare") had a broken rear tranny mount and it shook so badly that the front bumper fascia came loose and the steering wheel would deflect about 3/8" of an inch.
Once you get the mounts addressed, take the car for a roadtest. I think you'll be pleasantly surprised - the tranny issue may not be as severe as it seems now. If it still shifts hard (and delayed) after this, you may have to adjust the throttle pressure cable (Number #3 in the illustration).
http://www.hondaautomotiveparts.com/...+CONTROL+LEVER
This is what tells the Transmission how hard you're pressing the gas pedal and can effect shift timing, quality and even effect lock-up.
P
Old Nov 28, 2008 | 10:07 AM
how ever...
mounts on the I4 are easy to change, just do them one at a time and use a 2 by 6 so support the engine via oil pan or tans housing (for trans mount)
Old Dec 1, 2008 | 09:16 AM
crazyFaizy's Avatar
ohhhhhh..im sorry to hear that P_Adams hope this doesnt set you back alot,,,,and as for your last tips i well give it a try soon enought,,,
anyway i orderd a lubix50 ,,(still did not find lucas in uae) so im going to give this sulotion a try,,,and hope it works
the new mounts need to wait abit (currently lack the cash,,so it will wait abit)
thanks again for whoever particapaited in this conversation....
hondaaccordf23
Mar 18, 2012 07:54 PM
burntkookie
Jan 1, 2009 07:09 PM
ttcheung97
Nov 22, 2008 08:55 AM
GarageAlchemist
May 24, 2006 10:57 AM
joshuaaaronalpert
Jun 10, 2005 07:12 PM
