trying to get my heat working.
Old Nov 24, 2008 | 06:21 AM
dohc_profile's Avatar
Default trying to get my heat working.
so my heat doesnt work. i change the thermostat despite my car running at normal temp and heat still doesnt work. i changed my climate control and i made sure the water assembly valve is open. would air in the system cause my heat to fail? any help is appreciated. thanks in advance.
Old Nov 24, 2008 | 06:24 AM
AWD Terror's Avatar
Yes.
Have you recently changed the heater core, or did a flush of the coolant system? If so, it takes some driving to push fluid into the core since it sits in there upside down.
If not, I would have to say that you are either leaking coolant somewhere or possible have a bag hg which is pushing air into the core.
Old Nov 24, 2008 | 07:24 AM
Yuen001's Avatar
Originally Posted by AWD Terror
Yes.
or you lines going to the core could be clogged. not as likely, but could happen
Old Nov 24, 2008 | 07:39 AM
bag hg? meaning bad head gasket?
i'll trying bleeding the system and making sure its properly filled.
Old Nov 24, 2008 | 08:36 AM
95GSRnj's Avatar
is the blower motor turning on??
Old Nov 24, 2008 | 09:05 AM
Morasso's Avatar
Yeah, do you hear a fan turn on when you put on the heat? If not its your blower motor. I had the same problem with my old Integra.
If when you turn on the heat, the fan comes on, but some of the speeds dont work, then its your blower motor resistor.
Real easy fixes, at least they were on my old DA.
Old Nov 24, 2008 | 09:28 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Yup, good info! Test the resistor.
Old Nov 24, 2008 | 11:16 AM
grkblood13's Avatar
you said it takes some driving, what about just idling for a long time. i recently replaced my climate control unit and valve because the control unit was broke and the guy that did the swap didnt have the vavle hooked up. after installing i let the car idle for about half an hour and no heat. it never blew heat and it hasnt been driven yet.
Old Nov 24, 2008 | 11:56 AM
Yuen001's Avatar
agree to that, i just assumed that the fan was blowing
Old Nov 24, 2008 | 12:56 PM
you assumed correctly lol, the blower is fine, the speeds are fine. i changed thermostat, bled the system and filled it up. every hose is hot after the car reaches operating temp. i dont think its the heater core because theres no coolant smell in the car. im running out of ideas!
Old Nov 24, 2008 | 01:21 PM
grkblood13's Avatar
i think i found my problem to. im pretty sure i have a leak in my heater core since there water on the passenger side floor board the problems never stop...
Old Nov 24, 2008 | 02:12 PM
VOLCOMSTONE09's Avatar
is the metal rod hooked up to the valve on the heater core hose in the engine bay? possibly blend door not switching?
Old Nov 24, 2008 | 03:41 PM
grkblood13's Avatar
if u were referring to me then yea the valve arm is connected. i actually had to go get one from the junk yard because the guy who had the car took it off and also dented the outlet and inlet of the core. i manage to get a snug fit after a couple tries to stop outside leaking but either its still leaking and i cant see it or the core is busted. regardless, i bought a whole heater box with core for $60 shipping included on ebay today. saves me a trip to the junk yard i guess. prolly coulda gotten it a little cheap from the yard though. o well.
Old Nov 26, 2008 | 06:27 AM
AWD Terror's Avatar
You don't need to smell coolant for the heater core to be clogged. Wait until your car is at operational temp, lay down on the passanger floor and touch the heater core (can be done) to see if it's hot.
AWD Terror's Avatar
GTFO and start your own thread. Confusing as hell
Old Nov 30, 2008 | 08:08 AM
thank you everyone for the posts. after searching some more i read about the lever system behind the climate control thatopen a door allowing the air from around hte heater core to flow into the cabin, so i unstuck the levers and that solved everything. heat is working! and just in time.
motegicivic
13
Jul 4, 2011 05:35 PM
Swansen
Jan 4, 2009 08:42 PM
huge230
May 14, 2006 03:12 PM
superstud
Mar 14, 2004 08:54 PM
ZC88CRX
Nov 9, 2003 08:03 PM
