coolant system will not bleed, tried everything
I am having major trouble bleeding my cooling system. I get a few bubbles through the rad but not getting anywhere. I opened the bleeder as well. Tried both open and one at a time and it still wont bleed. I can even get coolant to come out of the bleeder screw. Any ideas
Re: coolant system will not bleed, tried everything (huge230)
if you get a good seal on the radiator, yes, that should work. if it is a clog the hose will simply stop running, like if you kink it. i'm interested in hearing your results, the only way your **** would get clogged is if you put contaminated coolant in or you have a blown headgasket.
Re: coolant system will not bleed, tried everything (ilu)
headgasket is not blown and coolant was brand new. COuld a bad water pump do this?
Re: (vtecspeed1320)
i had it running for a while and it still wont. I should tell you that there was no coolant in any of the lines anywhere because a swap was done. Still dont know what to try though
Andrew Sites
10-07-2001 08:36 PM
