question about flywheel.
Old Aug 1, 2002 | 05:25 AM
311's Avatar
311
Default question about flywheel.
I just received my ist gen b16 longblock yesterday, in place of where the flywheel mounts, there is a sliver disc about the same size as the flywheel, but has no teeth to grap the starter and has holes all over it. It looks like a piece of swiss cheese. what the hell is that?
Old Aug 1, 2002 | 05:29 AM
kenji's Avatar
Default Re: question about flywheel. (311)
The motor you received is from an automatic car. To be perfectly honest with you I forgot the name of the part you are mentioning. I am sure somebody on this board knows the name of it.
I have heard rumors (not sure if it is fact) that the automatic B16s have less aggresive camshafts. Can anybody confirm this?
-kenji
Old Aug 1, 2002 | 05:30 AM
311's Avatar
311
Default Re: question about flywheel. (kenji)
so i can just take off the piece of metel swiss cheese and put my 5 spd flywheel and clutch on right?
Old Aug 1, 2002 | 06:09 AM
kenji's Avatar
correct
-kenji
Old Aug 1, 2002 | 06:12 AM
311's Avatar
311
thanks for the quick response.
Old Aug 1, 2002 | 06:26 AM
DSF's Avatar
DSF
It's called a flexplate. The torque converter bolts to it.
And yes, auto B16 cams are very weak. You'll want to upgrade as soon as you hit VTEC.
Old Aug 1, 2002 | 06:43 AM
Audi A4's Avatar
Default Re: question about flywheel. (DSF)
didny yall say it was a auto matic?
Old Aug 1, 2002 | 06:45 AM
311's Avatar
311
so is it just the difference in the cams? if i get some manual b16 cams will it be back to normal power?
Old Aug 1, 2002 | 07:48 AM
SuperCivic's Avatar
everyone says ITR or CTR cams are the way to go..but if strapped for cash *like me* GSR cams are said to be a decent upgrade as well.
Old Aug 1, 2002 | 07:56 AM
311's Avatar
311
Default Re: question about flywheel. (SuperCivic)
could you notice a definate power loss with the auto cams?
Old Aug 1, 2002 | 08:15 AM
DSF's Avatar
DSF
No first hand experience, BUT have had friends that said it's a very noticable difference. Especially above 6500rpm.
Old Aug 2, 2002 | 10:02 PM
MisterB's Avatar
auto cams not too much fun and not a lot of pull up top get some ctr or itr and your set... up grade the springs and retainers cuz ive heared they suck too
Old Aug 3, 2002 | 03:25 AM
B18C-EJ1
Guest
Posts: n/a
As Kenji mentioned, yes, you can.
BUT!!!!!!!!!!!!!
Do NOT forget to change the bolts that attach the flywheel to the crank, as the AUTO uses a shorter bolt. You'll need to get the longer bolts ment for the manual transmission.
THIS IS IMPORTANT
LU!SKEY
Dec 19, 2010 11:48 AM
1gEF-8
Sep 21, 2005 09:19 AM
fe519
Mar 6, 2003 08:36 AM
Kataku2K3
Oct 11, 2002 09:49 AM
